Thread: 3G DAB Radio Coding
Results 1 to 10 of 14
  1. 3G DAB Radio Coding
    Jul 2013
    77 Post(s)
    Hi can someone with a 3G DAB radio installed let me know what the Coding should be for non Bose/B&O radio.
    Your help is appreciated.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  2. Re: 3G DAB Radio Coding
    Oct 2012
    Estonia
    64 Post(s)
    Go by this if its under address 56:
    (DAB with B&O): 01 01 03 01 00 00 00 00 01
    01 = AM/FM EUR (02 USA)
    01 = DAB (fixed value) (00 sirius USA)
    03 = Operational Mode (no idea what this means, have seen set to 05 for Q3, 07 ???)
    01 = External Amp (02 if internal i.e non B&O) it shud be vice versa for A4 as i read.
    00 = Sound Profile (no idea about this either 01)
    00 = No info
    00 = No info
    00 = No info
    01 = Chassis (01 is A5/A4 etc, 02 is Q3 I think, 00 is Q7)
    Your radio part number is?
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: 3G DAB Radio Coding
    Jul 2013
    77 Post(s)
    Thanks Gunnark100,
    I have a 4F0 035 061 B
    I think it should be
    01 01 03 02 01 00 00 00 00 00
    Dan
  4. Re: 3G DAB Radio Coding
    Oct 2012
    Estonia
    64 Post(s)
    Yes this should be ok, difference from ordinary radio is only 1 byte(second byte from left).
    Friend is running this, but its a4 no ext amp.
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 061 D HW: 4G0 035 061
    Component: Radio U DAB H60 0100
    Revision: AB001007 Serial number: 470H-0BB000695
    Coding: 010103020000000001
  5. Re: 3G DAB Radio Coding
    Jul 2013
    77 Post(s)
    The Coding worked now to get the Component Protection removed on Tuesday.
    The last set of digits must mean that the A6 is 00.
    00 = No info
    00 = No info
    00 = No info
    Thanks for all your help.
    Dan
  6. Re: 3G DAB Radio Coding
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by dan2485 View Post
    Glad to help, yep last byte is 00 for A6, but i played with those codes a bit in past, including last byte....did not see any difference or change with byte 2 operation mode, byte 4 sound profile and last one as well, so who knows how important those really are. Enjoy new radio!
  7. Re: 3G DAB Radio Coding
    Jul 2013
    77 Post(s)
    Now just one more question.
    I did a firmware update on the radio unit and now its working fine, the Component Protection fault is still logged in the faults page.
    Will the Component Protection kick in again or not.
    Dan
  8. Re: 3G DAB Radio Coding
    Oct 2012
    Estonia
    64 Post(s)
    Not fully sure what you asking regarding "again"....but cp needs to be removed(usual dealers job) if you retrofit used unit(this you know) and sometimes cp kicks in during sw update as well, but in this case you are able to remove this error with vcds!
  9. Re: 3G DAB Radio Coding
    Jul 2013
    77 Post(s)
    Thanks Gunnark100,
    What i mean is that the radio is now working fine, with no cutting out as it did before the software update.
    Only the fault code remains.
    Will the radio start to cut out if i leave the radio as is.
    Dan
  10. Re: 3G DAB Radio Coding
    Oct 2012
    Estonia
    64 Post(s)
    Thanks Gunnark100,
    Im not sure, as usual case is sound cuttoffs are due difference in sw stand or even wrong radio or gateway after hole retrofit and MU cp is related to sound. So i dont know, what is "only" radio "symptom" if cp is active. I would probably still go and remove cp, but you can wait as well, until you notice something which is not normal.
    Here, guy has cp active in amp but all good
    DSP AMP component protection removal - Page 2 - AudiWorld Forums
  1. Help with DAB radio
    By Scuda in forum In Car Entertainment
    Last Post: 28-01-2016, 11:47 PM
  2. DAB Radio on the CC
    By DabListener in forum Passat CC
    Last Post: 30-06-2013, 10:34 PM
  3. DAB radio
    By iallen1@btinter in forum Golf MK6 - 2009 - 2013
    Last Post: 04-12-2012, 08:03 PM
  4. DAB radio - do you still get FM?
    By thehorse in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-06-2012, 11:05 PM
  5. DAB Radio
    By Audi Nick in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-07-2008, 07:32 PM
