Thread: 2003 Passat 1.9TDI auto gearbox problems.
Results 1 to 10 of 14
  1. 2003 Passat 1.9TDI auto gearbox problems.
    Jan 2010
    Northampton
    I have a 2003 1.9TDI Passat with the 5-speed tiptronic auto gearbox. The car has covered 180,000 miles.
    When cold the auto gearbox and the tiptronic are failing to change gear. The problem corrects itself after about 20 minutes of driving. There are no unusual noises coming from the gearbox.
    The gearbox oil has never been changed because VW state that the gearbox is sealed for life and the oil should not be replaced.
    I can have the fault diagnoses by VW but I cannot think what could be causing the problem and so am reluctant to pay for the diagnosis if all they say is that the box needs replacing.
    Can anyone help with what the likely problem is or any tests that I can perform to narrow down the likely cause?
    Thanks for any help.
    Nick.
  2. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Apr 2016
    Ashburton
    you need to change the ATF fluid as it should be changed at 8 yr or between 60/80 k miles the vw official technical guide doesn't list this.
    Here is a web site with a guide to help you do it yourself.
    ATF fluid flush - tiptronic B5 VW Passat and Audi | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
    1 1 0
  3. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Jan 2010
    Northampton
    Can anybody tell me where I can buy a VAG diagnostics cable that will work with VCDS lite and is compatible with my Passat and supports Windows 10? I have looked on ebay but cannot find anything B% and Windows 10 compatible.
    If I can find the above cable and install VCDS lite will the software give me a readout of transmission fluid temperature?
  4. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Jul 2007
    glasgow
    35 Post(s)
    Change the oil first
  5. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Jan 2010
    Northampton
    I intend to change the fluid but to do that ideally I will need to know the atf temperature when refilling and that is why I wanted to know whether the VCDS lite will give me the atf temperature.
  6. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Jan 2010
    Northampton
  7. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Jan 2015
    Desborough Northants
    Hi Nick,
    I took mine to Midland Automatic Transmissions on Telford Way Industrial Estate. They changed the fluid and filters and all this for £200 sniffs. Save a lot of hassle and you know it's done with a warranty.
    Cheers Noony
  8. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Jan 2010
    Northampton
    I live in France and don't have access to auto gearbox specialists.
    The VW dealership will not change the gearbox fluid for me.
  9. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Jul 2007
    glasgow
    35 Post(s)
    can you email VW in France or indeed Germany to say you have gearbox problems and want to change oil to sort them out ??
  10. Re: 2003 Passat 1.9TDI auto gearbox problems.
    Jan 2010
    Northampton
    I intend to change the ATF myself.
    All I wish to know is whether VCDS lite will the software give me a readout of transmission fluid temperature?
  1. Please Help Electrical problems related to CCM - 2003 1.9tdi auto B5.5
    By Bodevo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-09-2016, 07:30 PM
  2. X reg Sharan 1.9TDI Auto - Gearbox problems - what to do?
    By Andy_L in forum Touran - Sharan - Caravelle
    Last Post: 11-09-2011, 03:23 PM
  3. bora 2003 auto gearbox noise
    By jamie weeks in forum Bora - 1998 - 2005
    Last Post: 01-10-2010, 09:54 AM
  4. Please Help 2003 vw sharan auto tiptronic gearbox
    By audireg in forum Touran - Sharan - Caravelle
    Last Post: 17-01-2010, 07:43 PM
  5. 1.9TDI Auto Gearbox problems
    By Scott58 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2009, 04:26 PM
