Thread: Random Electrical Happenings - Help appreciated
  1. Random Electrical Happenings - Help appreciated
    Aug 2016
    London
    2008 1.8T A4 Convertible which I've had with no problems for coming up to 3 years but over the past month have been getting random electrical faults, detailed below:
    -Roof will not operate (error code 02023 - Terminal 87 Not a plausible signal - Intermittent)
    Presumed this was an isolated error but now I'm not so sure because the following is now happening.
    -Randomly indicating that the rear fog light bulb requires replacement (it doesn't)
    -Drivers door window doesn't always close but will go back down again at the half way point
    -ESP light now flashing on and staying on but intermittently
    Any help or advise is gratefully received.
  2. Re: Random Electrical Happenings - Help appreciated
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Sometimes these are thrown up by a defective or failing battery. Have you tried clearing codes and re-checking what comes back? Terminal 87 is a relay issue if in fact there is a fault with the roof.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Random Electrical Happenings - Help appreciated
    Aug 2016
    London
    Thank you so much for the response, I'm a bit of a novice so all help is gratefully received.
    Since my first posted the ESP light hasn't returned nor the fog light bulb message, I did suspect it might have something to do with the rain last week!
    Roof however still not working and still showing up as an error.
  4. Re: Random Electrical Happenings - Help appreciated
    Nov 2008
    20 Post(s)
    It could indeed be a relay fault, or the wiring to it.
    Alan.
  5. Re: Random Electrical Happenings - Help appreciated
    1837 Post(s)
    The fault code on the roof can often be cleared by manually opening and fully closing and then fully opening the roof using the emergency key. It takes a bit of effort needing two people really but it often works.
  1. A6 Avant 2.7TDi 2008 - Strange electrical happenings!
    By Mike59 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-06-2013, 10:54 PM
  2. random electrical faults
    By alasorous in forum TT - 8N Forum - 1998 - 2006
    Last Post: 15-12-2009, 06:00 PM
  3. Please Help 1.6 Mk3 - Random cut outs - electrical?
    By listerthrawn in forum Golf MK3 - 1993 - 1999
    Last Post: 23-03-2009, 03:54 PM
  4. Please Help Random Electrical components and unplugged clip
    By STEVE-0 in forum Golf MK3 - 1993 - 1999
    Last Post: 06-08-2008, 05:22 PM
  5. Random electrical problem
    By Red October in forum The Commercial Range
    Last Post: 14-01-2008, 03:37 PM
