Thread: Touran 57 plate - no spare wheel, just foam and a pump
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #21
    1840 Post(s)
    Quote Originally Posted by nick-205 View Post
    just a can of foam and an air pump
    Sounds like my kind of girl.....
  2. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #22
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    [QUOTE=Christopherkhan;1030068]I have decided to fit full size spare wheel on tailgate!
    well done - you may not use it but it does give peace of mind !
    Skoda Octavia II SE 1.9PD TDI
  3. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #23
    Jan 2017
    Bedford, UK.
    Oldish thread but may help someone else. Ordered a space saver with my 7-seater Touran when bought new back in the noughties and have had to use it 3 or 4 times, most recently in the office car park this month. It lives lashed in the boot, 7 seats is rare for us these days but it will just about fit in the gap between row 3 and the tailgate if needed. Part Number was 1K0601011 and it was £150 +VAT. The supplied pump will get it to 60psi and when I actually came to use it this time the pressure was still bang on correct.
    On one service VW told me my gunk was past it's sell by date...threw it away.
  4. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #24
    Feb 2017
    Sheffield, GB
    Any suggestions which of the towbar mounts are best and least likely to damage other parts of the vehicle. I've just got my touran and don't want to start having to trust gunk in an emergency.
    Sent from my D2303 using Tapatalk
  5. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #25
    Mar 2017
    Hampshire UK
    Hi Everyone, I'm new to this forum but was active on ClubTouran until it's, err, 'demise'. Anyhow, jut thought I'd post a few pics of my answer to this problem. I don't fit it when I'm local to home but traveling any distance it's nice to know it's there. I put it together as an experiment, and 11 years later I'm still using it!
    Frame welded up from strip steel etc.
    Tubes mount onto bike rack uprights and secured with an R clip.
    Number plate mounts and light welded on, wheel strapped in place. The no. plate light is on a 7 pin plug so to open the boot you just unplug the light, remove the R clip and lift the whole unit off in one.
    We had many discussions on the old forum about this self same issue. Top box was ok if you could lift the wheel up there, skinny in the boot was ok as long as you remembered that if you used it you needed enough space in the boot for a full size wheel once you'd changed it!
    As far as towbars go, I couldn't get VW to fit one as I wanted a 2 bolt iso mounting and they didn't seem to understand my requirements. Also, as it would be fitted by an outside contractor they would only fit a bypass relay system with a buzzer for the trailer indicators and as the Touran is capable of supporting the socket via the canbus I wanted it done properly. So I got my friendly local Peugeot specialist to order me one direct from VW with the correct VW loom.
    I believe the actual manufacturer is Westfalia. In short, remove the back bumper, undo 4 bolts and remove the bumper iron, replace with modified bumper iron, cut a small clearance notch in the bumper and refit. The electrics weren't anywhere near as simple but came with good clear instructions and worked without programming but didn't operate the bulb fail system. My original VW dealer refused to program the electrics regardless of being given all the pick tickets and VW id/barcodes of the parts fitted as they still said it wasn't VW! Went to another dealer, got it all done in 30mins!
    A lot of rambling for a first post but I hope it's of use to someone...
    Rob.
  6. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #26
    Pembrokeshire
    22 Post(s)
    ^^^^ now thats my kind of thinking ^^^^
    welcome to the forum...
  7. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #27
    Mar 2017
    Hampshire UK
    Thankyou.
    The original plan was to use the bolts that fit the neck to the bumper beam so removing one bolt uses the other as a pivot allowing the wheel to lay face down and the boot to be opened - never got that far though!
    1 person in 10 understands binary, the other one doesn't.
  8. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #28
    Apr 2017
    Tg Mures, Romania
    Wow, i've been searching for something like this for ages. The lack of a spare tyre is like a no-go for me when buying a car and keep looking for solutions. Yours is the first i see and rocks.
    However, i would improve it somehow to let me open the boot more easely, like a towbar mount that can fold down or to the side.
  9. Re: Touran 57 plate - no spare wheel, just foam and a pump
    #29
    Apr 2017
    Tg Mures, Romania
    Quote Originally Posted by Christopherkhan View Post
    I have decided to fit full size spare wheel on tailgate! Attachment 31607
    Hey. Looks nice. You don't have any instructions about how did you do it? Or atleast some basic guide? TY
  1. 7 seat Touran to 5 seats and spare wheel.
    By driver2008 in forum Touran - Sharan - Caravelle
    Last Post: 25-05-2014, 09:50 PM
  2. Spare wheel?
    By bells0 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-10-2013, 05:12 PM
  3. Spare Wheel for a Touran
    By toffee68 in forum Touran - Sharan - Caravelle
    Last Post: 16-01-2010, 08:46 PM
  4. A3 05 plate spare kit needed
    By slinxy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-03-2009, 08:24 PM
