Thread: New code 03288 and no parking brake after 'fix'
  1. New code 03288 and no parking brake after 'fix'
    May 2012
    Lanarkshire Scotland
    Following on from the 'parking brake motor?' thread, I'm wondering how I can possible get thew parking brake working and clear this new code. I repaired a motor, refitted it to the car and with an epb tool that connects to the obd diagnostics socket, I activated the parking brake and then deactivated it (withought waiting 30 seconds, which, perhaps I should have). Can anyone shed any light on this and suggests a fix? I did clear the code but it came straight back. The epb too can still activate and deactivate the parking brake, although I'm not sure if it is both sides of the car....I can check that tomorrow.
  2. Re: New code 03288 and no parking brake after 'fix'
    Norfolk
    Never operate the epb if there is a chance that one of the motors is seized. It is likely that the cycling of the epb has caused the epb module to get confused and you are now stuck in cycling mode. Make sure both epb motors are free before continuing.
  3. Re: New code 03288 and no parking brake after 'fix'
    May 2012
    Thank Martin. Both motors are free to move. The right motor was new last month and I overhauled the left motor, cleaning all th gears. I'll report back when I've checked if I can hear the motoer winding on the left side. Thanks.
  4. Re: New code 03288 and no parking brake after 'fix'
    May 2012
    Both motors are winding. Will disconnecting the battery have any effect? Or should I cycle through activating and de activating the epb with the epb tool?
  5. Re: New code 03288 and no parking brake after 'fix'
    May 2012
    It's fixed! Looks like it just needed another cycle through. Phew!
  1. Question Any idea how to fix a sudden loss of MMI parking graphics?
    By Akash in forum VCDS - General Questions
    Last Post: 22-10-2014, 08:39 AM
  2. Question How do you jack up an A8? I want to fix the parking brake.
    By a8starr in forum A8 - S8 - V8
    Last Post: 24-08-2013, 11:51 AM
  3. won't accept security code on parking brake module 53
    By c.grex in forum VCDS - Help Requests
    Last Post: 20-08-2012, 10:36 AM
  4. Please Help Parking Brake Switch / Radio Code
    By fat controller in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-12-2010, 05:13 PM
  5. Parking Brake Switch / Radio Code
    By fat controller in forum Chat - Anything with wheels
    Last Post: 06-12-2010, 09:46 PM
