Thread: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Nov 2012
    Somerset UK
    Yep I can see it, two screws accessible the third not so, hence the removal of the inlet.
    The problem is I cannot hear the in tank fuel pump working, I've got a new one but methinks far less effort to fit that then this valve.
    Have checked all fuses and the relays but would appreciate if you can remember if you could hear your pump working when you had the fault? Or does the valve actually tell the in-tank fuel pump when to run?
  2. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    I activated the pump in VCDS so knew it was working
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Nov 2012
    Somerset UK
    Well I've changed the valve on the front of the pump, along with the pressure sensor and the fuel pressure regulator and mine still won't start.
    It is reading 745 across all 6
    So potentially either
    a) A fault with the cam follower in the pump, or
    b) A faulty fuel filter (although I don't think this would manifest with such a high pressure
    Car's been off the road for 3 weeks now
  4. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Jul 2020
    NORWAY
    Hi men. Did you find the problem and fix the car? I have exactly same problem with 2 cars some time pressure is 227 than car drive well but most is 482 than rpm idle jumping when release accelerator.
  5. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Dec 2007
    43 Post(s)
    Mine was fixed once i changed the regulator on the pump, pressure stopped surging and it stopped stalling
  6. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    Nov 2021
    Bosnia
    Hello which regulator did you change where is location i have same problem
  7. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    #17
    Dec 2007
    43 Post(s)
    Quote Originally Posted by Adnan1989 View Post
    Read post #9 for the answer.
  8. Re: Another 3.0 TDI Post. High fuel pressure 480 Bar on tick over and stalling
    #18
    Nov 2021
    Bosnia
    I have change sensor on pump same issue (was hard to change) than on rail sensor same 😂 injector changed same fuel filter same... on idle rpm stalling and fuel pressure 480bar... i have read ECU could be one have same issue... problem is there is no fault codes any 😔😔
  1. High fuel pressure A6 2.0 tdi 170 ps
    By Sambor11 in forum VCDS - General Questions
    Last Post: 14-03-2016, 08:35 PM
  2. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  3. Fuel Pressure PSI/BAR?
    By pizzaboy150 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-08-2013, 01:40 PM
  4. High pressure Fuel Pump Problems on 1.6 TDI
    By bdb in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2010, 10:25 AM
  5. Question 4 Bar Fuel Pressure regulator.
    By comfortablynumb in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2009, 03:29 PM
