Thread: Audi A5 power issue, hesitating! 😭
  1. Angry Audi A5 power issue, hesitating! 😭
    Aug 2016
    Tamworth
    Hi everyone.
    This is my first proper post on here so I hope it's in the right section!
    I had my 2008 Audi A5 3.0 tdi for 4 months now, nice car, but tbh I've had enough of it and hope somebody can help!
    Its most common fault is when I put my foot down I get about 2 seconds of good power.
    After that power is restricted for a few seconds, then will return for a split second, then go again.
    Its as if the fuel pressure is changing between good pressure and a lower pressure. Engine runs smoothly.
    I have the following fault codes which I believe to be nothing to do with this fault.....
    p0546 - sensor 1 for exhaust temperture bank short to ground
    p0638 - throttle body actuator bank 1, signal implausible
    p0671 - glow plug issue
    p161f - glow plugs again
    I have just changed the maf today and it has made no difference. Thanks in advance for
    any help.
  2. Re: Audi A5 power issue, hesitating! 😭
    Pembrokeshire
    22 Post(s)
    so go for a drive and look at the live data readings.
  3. Re: Audi A5 power issue, hesitating! 😭
    1837 Post(s)
    Check the manifold flap links to see if the have come off.
  4. Re: Audi A5 power issue, hesitating! 😭
    Aug 2016
    Tamworth
    I did this. My maf was faulty and replaced this but everything else looked fine. Problem still persists ☹️
  1. Power Steering Issue
    By uggers2k in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-03-2016, 07:26 PM
  2. pd 170 hesitating issue
    By phildaint in forum Golf MK5 - 2004 - 2009
    Last Post: 12-06-2013, 10:06 AM
  3. Power Steering Issue with 1994 Audi Coupe
    By minimadjamm in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 04-07-2009, 07:36 PM
  4. passat 1.8 20v turbo, hunting idle & hesitating on power
    By vwpassat1.8juic in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-12-2008, 07:32 PM
  5. Audi A3 2.0 TDI Hesitating when starting
    By dunnie in forum Audi A3 - Archive Topics
    Last Post: 19-10-2008, 11:32 PM
