Thread: Light problems on A6
Results 1 to 10 of 13
  1. Light problems on A6
    Aug 2016
    eAST gRINSTEAD
    Im after some help/advice please.
    Just recently bought a 2007 A6 2.0 TDI saloon and I keep getting the back right light cluster going down. Which means when I start up and drive a bit I get the warning beep and display shows break light reverse light and right indicator not working. However this is intermittent and yesterday evening and this morning all works fine again. Has anyone had the same problem or know why it is happening??
  2. Re: Light problems on A6
    Jul 2013
    76 Post(s)
    Contacts on the bulb holders corroded.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Light problems on A6
    May 2016
    London
    18 Post(s)
    Had same issue. I took it all out and cleaned connectors. Also it helps to twist the earth connector in the lamp a bit so it fits tighter. No issues since ...
    2006 Audi A6 3.0TDI quattro sline le mans | Daytona Grey Pearl
  4. Re: Light problems on A6
    May 2016
    London
    18 Post(s)
    Also if above is not helping Some ppl add additional earth cable
  5. Re: Light problems on A6
    Aug 2016
    eAST gRINSTEAD
    Thanks that's brilliant guys will try that tonight and let you know how I get on. again thanks very much
  6. Re: Light problems on A6
    Jul 2008
    Lisburn
    15 Post(s)
    After thinking i had a reverse light out i had a headache getting it to work again. the fix was to remove the other side...
    I would go with the earth thing alright
  7. Re: Light problems on A6
    Jul 2007
    Chorley
    I had a similar fault, intermittent and various bulbs. I spent ages cleaning terminals, changing bulbs etc. The light cluster was in and out of the car like a fiddlers elbow. Despite all that time and effort the fault remained.
    Then I bought a new bulb holder unit from the dealer for £35 ish IIRC. Fitted in five minutes, problem went away!
    A6 2007 2.0 TDI Saloon
    A4 2002 1.9 TDI Avant
  8. Re: Light problems on A6
    May 2016
    London
    18 Post(s)
    New holder was my next solution but twisting the earth pin helped the most for me as it has better contact and doesn't burn the connector. We will see how long will it last ...
  9. Re: Light problems on A6
    Aug 2016
    eAST gRINSTEAD
    Thanks guys. I have looked at the terminals and none corroded I even cleaned the tips of the bulbs to make connection better. Pulled up the tab the bulb sits on to make it tighter. worked ok for a day then started to fail again. I haven't tried the earth thing yet but was thinking just get a new bulb holder. I know a picture was posted of the earth cable by niedzial1983 but cant really see it clearly and not knowing anything about cars or cars electrics I wouldn't know where to start with earth cables lol.
  10. Re: Light problems on A6
    Nov 2012
    Somerset UK
    Quote Originally Posted by Mark Curtis View Post
    If you can change a 13amp domestic plug the world is your whelk!
  1. A3 hazzard warning light and air bag light problems
    By sutty100 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-09-2010, 12:28 PM
  2. A6 Rear Light Problems
    By Neil Davison in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2009, 04:50 PM
  3. Please Help Interior light problems!
    By soulstyler in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2009, 02:11 PM
  4. Emmissions Light - Problems
    By ad1966 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2009, 01:40 PM
  5. Light problems
    By howard13 in forum Passat - Archive Topics
    Last Post: 31-07-2006, 08:46 PM
