Thread: New turbo, what else do i need?
Results 11 to 20 of 26
  1. Re: New turbo, what else do i need?
    Aug 2016
    Cambridge, UK
    Fair enough, also, my turbo makes a whizzing noise as i go through the gears, does this just mean its being stretched? (happend more after remap)
  2. Re: New turbo, what else do i need?
    Sep 2009
    London/Bucks England
    Could the extra load on older bearings on the turbo - could be un-related, depends what the map is doing. Is it delivering extra pressure or just fueling? Could just be a wearing out turbo, scored turbine etc.
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
  3. Re: New turbo, what else do i need?
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    11 Post(s)
    I'm just curious, but define "intake" upgrade? Pre-turbo... Post turbo? Im not all that familiar with golf layout as I drive a b5.5 Passat but VW did a pretty decent job of setting up the air intake on it... Maybe the golf is different... I know people that stick cone filters on passats etc and it's a waste of time.... Just makes the intercooler less efficient as it draws air from a hot engine bay instead of a forced feed from the grille... Maybe I'm off on a tangent. Who knows... The hour is late and the eyelids heavy... Lol.
    Mini
  4. Re: New turbo, what else do i need?
    Aug 2016
    Cambridge, UK
    Yeah, ive done some research and a cone filter is what im looking at, looks like it does little to **** all in terms of performance, especially for the cost 1-200 squids, might give that one a miss..
  5. Re: New turbo, what else do i need?
    Sep 2009
    A better flowing / larger intercooler, throttle bod, manifolds etc is what I would be thinking for a turbo. But the turbo will be doing the most work so probably a better inter-cooler, especially if its an uprated turbo with higher pressures. But you have to be pretty serious and on a plan to do all that work - depends if the rest can hold up to the wound up pressures also. Although for a diesel the butterfly is to stop it running away with itself.. so not sure on that one!
  6. Re: New turbo, what else do i need?
    Aug 2016
    Cambridge, UK
    Im a serious guy, ive got the money, and the tools. Will let my mechanic mate at local VW do my turbo, but is an intercooler upgrade something i can delve into?
  7. Re: New turbo, what else do i need?
    #17
    Sep 2009
    Yeah, should be straight forward to fit too, if you are going to get it mapped out
  8. Re: New turbo, what else do i need?
    #18
    Aug 2016
    Cambridge, UK
    Cool, and in terms of remapping. Is it worth me buying a blue fin, as opposed to taking it to my local ECU place costing £200 each time, so i can just programme my car after i mod it, or is ECU remapping after mods much more complicated requiring a Dyno?
  9. Re: New turbo, what else do i need?
    #19
    Dec 2013
    11 Post(s)
    Personally, if I was gonna do all that work I would probably buy another engine and rebuild it from bottom up. Big end bearings etc. Start with a fresh canvass then and no nasty surprises. Second engines are cheap enough on the bay usually (engine code dependant obviously). Once built how I wanted, I would simply swap it into the car.. Cone filters on tdis are a waste of time IMO. You've got a turbo to force air into the engine... It's not gonna run out of air any more than we are. Colder the better though, intercooler is easy enough, have a look on dark side developments for a kit.
    Mini
  10. Re: New turbo, what else do i need?
    #20
    Aug 2016
    Cambridge, UK
    Cheers pal, and yeah, im just getting into the whole car mod game after buying a car thats worth modding for the crack, i think an engine rebuild is something ill look at near christmas time, when i know the car inside out, so i can build it to my spec. Also gotta consider insurance, sitting at 1400 in my dads name with declaring exhaust mod and alloys.
  1. Please Help BLB turbo fitted Friday & failed in garage. Told the turbo has wrong tuning
    By A4_2.0TDI in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-10-2013, 11:23 PM
  2. Blown turbo. Is it possible to replace a k03 turbo with k04 turbo
    By A4slineavant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2012, 07:45 AM
  3. Turbo Acuator Length adjustment on VNT TURBO on 1.9 Sharan
    By sharan1.9 in forum Touran - Sharan - Caravelle
    Last Post: 13-12-2010, 05:36 AM
  4. Question has anyone used a BMC CBA induction on audi a4 turbo or non turbo? please reply
    By bazz_a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-07-2009, 08:18 PM
  5. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
