Thread: Golf wont start
Results 11 to 20 of 21
  1. Re: Golf wont start
    Aug 2016
    warrington
    Is that the ecu or fuel pump one i have changed both
    Sent from my SM-G928F using Tapatalk
  2. Re: Golf wont start
    Sep 2009
    London/Bucks England
    Hmm. Well that's odd. You might need to get a test light out in check whats powered with the ignition on. The fuel pump is priming, its cranking and no spark.. so whatever that is, its preventing being sparked from the ignition module fed by the ECU. Is the immobiliser coded in to the ECU? You will need to do this with VCDS.
    Although I would have thought it would cut the fuel pump, i'm not sure on that though.
    It has to be something fairly straight forward. Is the loom intact? You might need to do some tracing of wires. Has the car been fault scanned at any time? Sounds like it needs one.
    Fuses are another one.
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
  3. Re: Golf wont start
    Aug 2016
    warrington
    Yeh done every thing had auto electrian out he said it was the ecu but its not
  4. Re: Golf wont start
    Sep 2009
    Did he give you any codes or any information?
    ECU's are quite hardy, so if its not functioning, its most likely the wiring going to it
  5. Re: Golf wont start
    Aug 2016
    warrington
    Nothing said it wasnt showing any was thinking it could be the loom
  6. Re: Golf wont start
    Jul 2007
    glasgow
    35 Post(s)
    what about the hall sender and dizzy below the distributor cap ?
  7. Re: Golf wont start
    #17
    Aug 2016
    warrington
    Just changing that tomorrow see if its that if not really dont know what it could be
  8. Re: Golf wont start
    #18
    Sep 2009
    hall sender should give a code, G60 iirc. When mine failed it did, although after repairing my aging loom you never know what you might find.
  9. Re: Golf wont start
    #19
    Aug 2016
    warrington
    Had no codes come up its a **** take lol
  10. Re: Golf wont start
    #20
    Sep 2009
    You need a couple of cans of contact cleaner, and go through the loom in the bay. I will update my thread later might give you some points to check as the looms will be pretty similar. Years of grime will cover up broken insulation and even increase wire resistance maybe even cause a short or two. I was shocked at how many small nicks I found in the wires once I did this.
    Be prepared with connectors, electrical tape and some crimps if needed. If you can get your hands on a test light that would be best. Not a quick job, but if you're thorough you will find it. You should be able to just ground it to the car body and test for positive connections (or vice versa)
    Carb cleaner works, but contact cleaner is best.
  1. Please Help golf wont start
    By john hh in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2012, 02:04 PM
  2. Vw golf wont start
    By dan2010 in forum VCDS - Help Requests
    Last Post: 26-01-2010, 09:34 PM
  3. Vw Golf wont start!!
    By scottywales in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2009, 08:23 PM
  4. Golf wont start
    By dr_k in forum Golf MK4 - 1999 - 2004
    Last Post: 01-12-2008, 03:17 PM
  5. golf wont start sometimes help!
    By JohnCunningham in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2008, 10:18 AM
