Thread: fix front wipers
  1. fix front wipers
    Nov 2010
    halkirk caithness
    hi how do i fix front wipers as they are very slow to sweep the glass and sometimes stop half way on glass
  2. Re: fix front wipers
    Jun 2016
    Southampton England
    One of my cars had this fixed before I bought it. It had been parked up for quite some time, it's common apparently.
    as far as I'm aware you need to pull the plastic cover off under the windscreen. It comes off really easy. Then you should be able to get to the wiper linkage, hit the pivoting bits with a ton of oil/greese. Try the wipers, keep going until they are working properly. While your there you can check the drain holes under the battery, make sure you haven't got water sitting in the chamber. They get clogged with leaves and dirt then it fills up and floods into the car, takes a couple minutes to fix it versus ages to dry the carpet
    good luck
  3. Re: fix front wipers
    Nov 2010
    halkirk caithness
    wiper arms are really stiff
  4. Re: fix front wipers
    Jun 2016
    Southampton England
    Have you cleaned up and greased the pivoting parts on the linkage? If your just trying to pull them by hand they will be really stiff, your moving the linkage, both arms and the motor. Mine where fixed 4 years ago and have been fine ever since, nothing needed replacing luckily
  5. fix front wipers
    Sep 2007
    Windy Westcountry!
    Hi Abby1
    Pretty common fault on the Audi. The most likely problem is that the spindles are seized in the bushing. I did an overhaul of mine last weekend. There's a good guide here
    http://www.audiworld.com/forums/a4-b6-platform-discussion-34/diy-solving-%22crap-my-goddamn-wipers-stuck-middle-windshield%22-problem-2383247//"]AudiWorld Forums
    It's not a tough job it's just a bit of ball ache getting the arms and motor unit out. In my case I did have to release the ECU and wiggle it out the way. I also had to pop the ball joints. Other guides seem to suggest you don't need to do this but goddamit I really couldn't.
    Do be careful moving the ECU. Also, if like mine, the spindles are really really seized, use a copper hammer or a block of wood to bash them out with plus gas (after removing circlip). I didn't and rounded the threads on one of them and had to re cut the thread.
    It's really worth giving these an overhaul as it'll only get worse. You'll end up with a knackered motor and that's more expensive that a mornings work and a can or grease.
  6. Re: fix front wipers
    Nov 2010
    halkirk caithness
    yeah same problem got it fixed plenty grease and a pain to remove
    cheers
  1. How to replace front speakers and fix problem with the rear lights ?
    By edzha90 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2015, 09:42 PM
  2. Allroad will not lift In front after leak fix
    By csalhus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-12-2012, 08:12 PM
  3. Please Help Front Wipers
    By kite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-04-2012, 02:51 PM
  4. Please Help Front Wipers
    By tigerminx1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-03-2012, 08:06 PM
  5. Front slow wipers, faulty wiper motor, wipers park intermittently
    By guddo1969 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-12-2008, 09:51 AM
