Thread: quattro lock repair question(s)
  1. quattro lock repair question(s)
    Jul 2016
    Dundee Tayside
    Needing to replace the lock barrel and wondering if its basically a straight forward job - pop the barrel out and slot in the new one? I've not taken off the door panel to have a look yet so also wondering if I am going to have to drill out rivets to remove any inner door panels to get to the lock in order to remove it?
    Another thing I need to look at is the door open warning light comes on although the door is shut properly. Where is the sensor for that or is there any way to simply disable it as it is getting a bit annoying
    Also locking /door related - when I got the car the fob doesn't work - at the moment I am just assuming the batteries are just flat - if I stick in new batteries am I going to need to get the fob re-coded to work?
  2. Re: quattro lock repair question(s)
    Jul 2011
    Norway
    Dundee ! Nice city. I,ve been there! - some 35 yrs. ago though Guess alot have changed since then. About your car the barrel is straight forward. First remove the door panel, two small screws both sides near the top, pull the connector of the switches and the panel
    can be lifted upwards. Now you can eighter take off the vindow frame or you can do it with the frame in place, it's a tight squees but it's doable.
    The problem is a faulty micro switch in the door lock
  3. Re: quattro lock repair question(s)
    Jul 2016
    Dundee Tayside
    Bit different than it was 35 years ago - not to much though. A lot less to take off than my fabia was anyway - sounds nice and easy.
    Had a feeling it was the switch - looks like I will have to replace both o/s/f and n/s/f switches then as it is intermittent on both doors
    cheers
    Audi A6 Quattro 2.8 v6
  4. Re: quattro lock repair question(s)
    Jul 2011
    Norway
    Morning. Some yrs. ago I found those switches on ebay, take a look because the dealer will only sell you the complete door lock ( with the switch) If I remember right the lock barrel will only come out together with the door handle. To be able to wiggle
    the door handle out you have to remove the pushrod from it first, it,s kept in place of some kind of locking pin, maybe you can google up a picture of it ?
  5. Re: quattro lock repair question(s)
    Jul 2016
    Dundee Tayside
    Had a look on ebay UK and could not find anything - prob best look on the german one later but can get a complete unit for about £30 as a direct replacement although coming from Hong Kong.
    With any luck it is just a dodgy connection though but will see when i get round to whipping off the door cards next week or maybe just see if its possible to unplug the sensor so it doesn't send a signal at all. I did see somewhere (cant remeber where) if you disconnect the interior door lamps or something it cancels the signal .
  6. Re: quattro lock repair question(s)
    Jul 2016
    Dundee Tayside
    Had another look on ebay -I am guessing this is what I will probably be needing then ?
  1. Question Passat B5.5 Estate needs tailgate microswitch and rear passanger door lock repair
    By berrick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2014, 11:50 AM
  2. Question Quattro owners - 3.0 TDI Quattro - tyre scrubbing on half to full lock - any ideas?
    By Thon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-03-2012, 02:20 PM
  3. Lupo door lock repair
    By davidsaglover in forum New Member Introductions
    Last Post: 08-12-2011, 09:11 AM
  4. Accident- Body repair question.
    By Satch in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-02-2009, 10:47 AM
  5. Aircon fault repair question
    By Bonus77 in forum Passat - Archive Topics
    Last Post: 17-09-2006, 12:58 PM
