Thread: Hydraulic brake servo fluid?
  1. Question Hydraulic brake servo fluid?
    Aug 2016
    S Wales
    I'm finishing a kit project using a Audi hydraulic brake servo.
    The Question that has stumped me is what fluid is in the servo side of the unit?
    I can find references to the pump being a dual pump shared with the power steering and some schematic drawings that appear to list the breaking side of the pump with a separate fluid reservoir for the servo but little as to whether it is Hydraulic power steering fluid or braking fluid used to power the servo side?
    What I do know is that if I continue and fill it with the wrong fluid the seals will be destroyed which is an expensive way to learn.
    Photo attached if it helps.
  2. Re: Hydraulic brake servo fluid?
    Pembrokeshire
    22 Post(s)
    what car did it come out of, looks like an audi 80 coupe. if so, thats the one with the hydraulic' grenade' pressure resevoir, in which case you want the green mineral fluid for power steering.
  3. Re: Hydraulic brake servo fluid?
    Aug 2016
    S Wales
    I think it was from a random ebay sale. But Audi 40 rings a bell.
    Thanks for the tip, I'll know not to put brake fluid in it as that would probably be a quick end to all the rubber in it.
  1. Question Brake fluid, coolant, powers steering fluid.... advise please
    By IlovemyVW in forum Golf MK4 - 1999 - 2004
    Last Post: 17-11-2013, 07:43 PM
  2. 1996 Cabriolet Hydraulic Servo fault
    By mhobson in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-09-2012, 12:11 PM
  3. Power Steering rack/hydraulic fluid line
    By 95cabrio in forum 80 - 90
    Last Post: 17-01-2012, 08:48 PM
  4. Hydraulic Fluid
    By Glajohn in forum 80 - 90
    Last Post: 11-09-2009, 11:19 PM
  5. mineral based hydraulic fluid
    By wazobia in forum Passat - Archive Topics
    Last Post: 01-03-2007, 07:43 AM
free web
stats
