was playing around with vcds and the green menu and I really messed everything up on my audi A8 4h with 3g+ but after spending a total of 18hrs i have managed to restore the setting using vcds and the green menu however one last setting i cant quite figure out is the background lighting on my car is changed from being able to change the brightness/colour/and some other setting to just have a knob which just displays brightness if someone can help me with this that would be great or even better if someone has the green menu activated in there a8 a snapshot of green menu with regards to the interior light settings would be great and also the default vcds codes.
