Thread: Tapping noise at front end wheel / joint area.
  1. Tapping noise at front end wheel / joint area.
    Jul 2016
    South Wales
    • Hi, Let me start with saying I am new to this site ( Just Signed up ), so I apologise if this subject has been dealt with already.
      I have an Audi A4 S Line ( B7 ) and it has a really annoying tapping coming from the both front Wheel / Joint area of my car. These seams to be quite a common fault as I have searched on line, but no one seams to have a definite solution.
      I have changed all of the joints which needed changing and even had new pads and discs fitted, but the noise is just getting gradually worse. It is now embarrassing to drive. PLEASE HELP!
      If any of you know of the solution, please let me know. Alternatively, if anyone knows where I can buy a cheap balaclava that may be an option.
  2. Re: Tapping noise at front end wheel / joint area.
    Jul 2016
    South Wales
    • On Saturday, I changed the rubber boots that the calliper guide pins slide on, as a mechanic I met suggested that's what it could be. I also cleaned all 10 years of crap from all the areas that the pads slide across and greased everything back up, but it made no difference. I fact it has probably made it worse, now everything is clean and moving more freely. I did notice there is a retaining spring misses off of the outer side of the calliper. I will be getting & fitting as soon as I can get back down to Audi.
      The tapping is almost defiantly coming from the brakes / calliper, as the noise stops when I press the bake peddle, even just ever so slightly.
  1. metallic tapping noise from engine area
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2014, 08:00 PM
  2. Clicking noise from front wheel when turning - CV Joint??
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2012, 08:40 PM
  3. CV Joint or Wheel Bearing noise?
    By Amsel in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-02-2012, 05:45 PM
  4. Replies: 6
    Last Post: 31-01-2012, 04:46 PM
  5. Front Wheel Bearing or CV Joint????
    By dazza23 in forum Golf MK5 - 2004 - 2009
    Last Post: 24-12-2009, 11:39 AM
