Thread: 3.0 tdi throttle pause
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
  1. 3.0 tdi throttle pause
    Aug 2007
    Asnières-sur-Blour, Vienne, France
    Had my A6 Allroad for over 4 years largely pleased with it but recently when you press the accelerator whether hard or soft at low or high speeds, there is an annoying pause before the engine pulls. Before you just had to touch the accelerator for an immediate response. VCDS shows no faults. Can there be ECU problems?
    I look forward to constructive suggestions.
    Thanks,
    Michael
  2. Re: 3.0 tdi throttle pause
    Feb 2016
    Hungary
    113 Post(s)
    Quote Originally Posted by mhobson View Post
    It sounds like a turbo hole problem for me, maybe for some reason your charger has a slower response, or there could be a problem with the airflow.
    I had a similar problem with my car. There was an air pipe in the engine area, which was almost full of soot, so my engine was even shut itself down, while there were no error codes in the MMI. After the cleaning of this pipe, I felt that the engine became stronger, so maybe this could be an answer for your problem too.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  3. Re: 3.0 tdi throttle pause
    Aug 2007
    Thank you for that, however the pause occurs before you would expect much turbo effect, there are no whistling noises which may suggest a vacuum leak and after the brief pause it accelerates a normal
  4. Re: 3.0 tdi throttle pause
    Jul 2015
    Staffs
    46 Post(s)
    3.0 tdi rarely has turbo issues, just as ECU problems are again rare. Could be a throttle body problem, or maybe a throttle pedal postition sensor problem.
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: 3.0 tdi throttle pause
    Aug 2007
    Quote Originally Posted by rowdy-999 View Post
    Would those issues not have raised an engine fault on VCDS? Otherwise how would you be able to find the problem?
  6. Re: 3.0 tdi throttle pause
    Jul 2015
    Staffs
    46 Post(s)
    Not sure if this will help:
    Manual throttle body adaptation:
    "The Throttle is "Drive By Wire" and adapts to your particular driving style. Do a TBA Throttle body adaption).
    1. Get in your car, it doesn't matter if you close the door or not.
    2. Turn the key to the on position, the position just before the starter turns over.
    3. Press the gas pedal to the floor with the key in the "on" position.
    4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position(don't remove the key), then release the gas pedal.
    5. Wait 2 mins. for a full alignment. During this time you may hear very faint noises and clicks. I
    only heard one sitting in my car, if I got out and popped the hood I might hear more.
    6. Drive the car as you always do.
    Depending on your driving style, this may or may not be a big factor. I do a lot of city driving so
    I noticed a big change after erasing my history. It is not hard to do this, just follow the
    instructions - Key on, pedal down, 5 sec, key off pedal up, wait 2 minutes.
    Keep the key in for the entire thing.
    Ian
    1 1 0
  7. Re: 3.0 tdi throttle pause
    Feb 2016
    Hungary
    113 Post(s)
    Honestly, I mean quite the opposite situation, maybe some air pipe is so clogged, that the turbo can't get enough air to spin up, and that may cause a delay. Your problem sounds similar to me, because there was no noise, or error codes in my case either.
  8. Re: 3.0 tdi throttle pause
    Aug 2007
    Quote Originally Posted by AT. View Post
    I know what you mean, but I live in rural France, rarely travel in towns and the car has a DPF which I know is a pain and and gets blocked in city driving but particle readings are always low so I feel that the car runs quite clean, I normally get just above or below 40 mpg, and after the short pause on the throttle the car pulls as well as ever, the boost pipe is steel and quite big 10 or 12 mm so I expect it would nedd quite a lot of gunk to block it. The carvuses very little oil, I never have to top it up between oil changes.
  9. Re: 3.0 tdi throttle pause
    Feb 2016
    London
    13 Post(s)
    Symptomatic of a sticky EGR valve that is not closing fast enough.
    2011 A6 Allroad 3.0TDI
  10. Re: 3.0 tdi throttle pause
    Nov 2012
    Somerset UK
    Maybe worth looking at this thread as well
    Good preventative maintenance and I noticed my throttle response improved afterwards
    TB Cleaning Photos
    Once I've bought my new manifolds I'll be getting an EGR delete and have the EGR mapped out...which weirdly costs the same as a full remap!?
  1. Replies: 0
    Last Post: 29-10-2015, 12:52 PM
  2. Question Slight pause on changing gear s4
    By maccayzf in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-03-2013, 06:24 PM
  3. Does you "Media" pause when TP message arrives?
    By nealeb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-01-2012, 02:29 PM
  4. Please Help A8 - CD, IPod and radio stuck on pause
    By phadaway in forum A8 - S8 - V8
    Last Post: 02-01-2012, 08:52 PM
  5. Noise/Clunk/Pause when braking to standstill
    By jamoca in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 11:59 PM
