Thread: Aftermarket stereo install
  1. Question Aftermarket stereo install
    Nov 2015
    Inverness
    Hi all
    I have a sony xplod stereo but only the front speakers are working. Looked through google and they say the rear speakers are powered by a amp.
    When I try wiring in the amp for the rear speakers all I get is a hissing noise through them.
    They worked perfect with the original stereo.
    Any Ideas?
  2. Re: Aftermarket stereo install
    Pembrokeshire
    22 Post(s)
    are you connecting the amp to the speaker outputs on the stereo ?
  3. Re: Aftermarket stereo install
    Nov 2015
    Inverness
    no, through the rca sub out put's.
  4. Re: Aftermarket stereo install
    Pembrokeshire
    22 Post(s)
    cool, thats what i hoped.. should work. dunno why its not then..
  5. Re: Aftermarket stereo install
    Pembrokeshire
    22 Post(s)
    unless the amp isnt being turned on of course.. ??
  6. Re: Aftermarket stereo install
    Nov 2015
    Inverness
    connected the amp to the remote wire on the stereo
  7. Re: Aftermarket stereo install
    Pembrokeshire
    22 Post(s)
    ok, in that case i really cant help. only other suggestion is to run new cables direct to the rear speakers and not use the amp..
  8. Re: Aftermarket stereo install
    Nov 2015
    Inverness
    Thanks for the replies
    How do I get access to the speaker wires as there mounted in the doors?
    What colour is the wire for the second live for turning on the stereo?
    I know which one is the constant live for the memory.
  9. Re: Aftermarket stereo install
    Pembrokeshire
    22 Post(s)
    if you find the amp then the speaker wires will come out of it, you could connect onto these to save stripping the doors down.
  1. 2003 VW Passat GLS Sedan - Aftermarket Stereo Install - Keysense?
    By Patrick Welch in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-09-2014, 01:14 AM
  2. Aftermarket Headunit Install
    By Dhar_2 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-03-2014, 10:52 PM
  3. Question A4 B6 Aftermarket Stereo Install
    By Scooby_doo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-02-2010, 12:12 PM
  4. Aftermarket stereo install. Rear amplifier?
    By AdamC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-08-2009, 12:13 PM
  5. Help needed with aftermarket stereo install
    By frankieboy in forum Bora - 1998 - 2005
    Last Post: 18-07-2007, 02:40 PM
