Thread: Passat 2.0tdi 2007 170 dsg hesitant starting from cold
  1. Passat 2.0tdi 2007 170 dsg hesitant starting from cold
    Mar 2009
    Can anyone give me some advice my Passat is hesitant to start just in the morning usually ok through out the day once it's been started ,not sure if it's the glow plugs that need changing but there quite expensive for that particular model just don't want to replace them for the sake of it ,also could it be a fuel return issue ?.i did replace the vacuum pump about 3 months ago and Intank fuel pump but car was fine after I replace them parts , I've tried my obd2 reader but doesn't work to see if any faults had come up
  2. Re: Passat 2.0tdi 2007 170 dsg hesitant starting from cold
    Mar 2009
    I removed the glow plugs to check the resistance but doesn't give a reading at all checked an old Peugeot glow plug which was no good and read 1 ohms ,but these plugs I can't get a reading from them ?
  1. Passat 2.0tdi dsg 170 2007 misfires over 3000rpm
    By scanny in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-04-2016, 08:05 PM
  2. Please Help A3 2.0tdi 170 Quattro 2007
    By dunclie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-05-2015, 07:10 PM
  3. Question Golf Mk5 - 170 Sport - Hesitant Starting
    By VeDubDan in forum Golf MK5 - 2004 - 2009
    Last Post: 13-02-2014, 10:50 AM
  4. Volkswagen Passat 2.0TDI SE DSG AUTO 2007
    By markvw in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-12-2012, 08:12 AM
  5. Please Help 2007 A4 2.0TDI 170 Juddering and hesitant on pull away
    By redders80 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-06-2011, 12:06 PM
