Thread: Speed Display in SatNav??
Results 1 to 10 of 15
  1. Question Speed Display in SatNav??
    Apr 2016
    Sudbury, Suffolk
    Apologies if this has been answered before (I did a search - honest!) but is it possible to have the car's speed and/or the prevailing speed limit showing on both or either of the sat-nav displays please?
    I have found a menu item for speed and checked it but it doesn't seem to work!
    2 0 0
  2. Re: Speed Display in SatNav??
    Feb 2013
    Gloucester
    57 Post(s)
    You can't have the cars speed displayed but can have the current speed limit for the road. No idea how to code it was though, was on from factory in the wife A5 and my A7.
  3. Re: Speed Display in SatNav??
    Mar 2015
    Melton Mowbray
    10 Post(s)
    Speed limit (based on type of road) is on by default in my 2015 FL A6. Shows it in the bottom right corner of the map, and don't think I've actively turned anything on to make it show
    It sometimes gets it wrong though.
    If you want it to recognise speed limit signs when you pass them, and display that - then that's an expensive option to tick.
  4. Re: Speed Display in SatNav??
    Apr 2009
    Surrey
    171 Post(s)
    Not actually based on the tupe of road, it is actually part of the mapping database. On my 2012 A6 with RMC had the amusing situation that on a 40 mph road near me it showed 40mph in one direction and 30 in the other. Has been sorted on my 2015 car
  5. Re: Speed Display in SatNav??
    Apr 2016
    Sudbury, Suffolk
    Should have stated that my car is a 2015 Allroad. So from the above it appears that the speed limit should be on the display by default - but it ain't!
  6. Re: Speed Display in SatNav??
    Jul 2013
    Yorkshire
    18 Post(s)
    Have you looked in satnav settings? should be in there; like this:
  7. Re: Speed Display in SatNav??
    Jul 2013
    Yorkshire
    18 Post(s)
    Need to add, it doesn't show up on all roads. e.g. some smaller rural roads.
  8. Re: Speed Display in SatNav??
    Feb 2016
    Hungary
    113 Post(s)
    Quote Originally Posted by A6ian View Post
    Have you looked in satnav settings? should be in there; like this:IMG_1120.JPG
    Another plausible issue could be, that this option was not set for all the cars, there is a VCDS trick to enable this option if it was not enabled by default.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  9. Re: Speed Display in SatNav??
    Jul 2013
    Yorkshire
    18 Post(s)
    Quote Originally Posted by AT. View Post
    This is how mine came set as standard.
  10. Re: Speed Display in SatNav??
    Apr 2016
    Sudbury, Suffolk
    Yes that is how my settings look!
  1. Question Lane information display on satnav
    By GrolschUK in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-06-2016, 02:35 PM
  2. Speed cameras and satnav
    By Wokingwedger in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-09-2015, 12:23 PM
  3. Question RNS-E Satnav display on dashboard - is it possible?
    By mjhamilton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-09-2013, 09:35 AM
  4. Instantaneous speed from Phaeton SatNav?
    By MadMacStew in forum In Car Entertainment
    Last Post: 21-12-2008, 09:33 PM
  5. GPS speed readout on Phaeton SatNav?
    By MadMacStew in forum Chat - Anything with wheels
    Last Post: 10-12-2008, 05:18 PM
