Thread: VW T5 Vacuum pump readings
Results 1 to 10 of 12
  1. VW T5 Vacuum pump readings
    Jul 2008
    Hi there
    I can't see where else to post this so please correct me if it's wrong.
    The tandem vacuum/fuel pump on a 2007 VW T5 2.5TDI. Does anyone know what vacuum readings I should be getting at idle and under load please?
    I get underboost problems (limp mode) for the turbo and also the brake pedal feels a little harder than usual. To me this would imply a lack of vacuum pressure from the pump or a leak in the system.
    The van has a new turbo, new N75, MAP and MAF sensors, intercooler, refurbed injectors.... smoke tested vacuum lines and high pressure pipes.
    If it's not this then I'm still at a complete loss as to what causes the apparent turbo underboost fault code and then limp mode.
    Many thanks if you can help,
    James
  2. Re: VW T5 Vacuum pump readings
    Pembrokeshire
    22 Post(s)
    20 mm hg , same as a petrol car at idle, but inlike a petrol this reading should stay about the same as you rev it.
  3. Re: VW T5 Vacuum pump readings
    Jul 2008
    Thanks for your post Zollaf.
    I don't suppose you know what the fuel pressure out the same tandem pump should be do you?
    James
  4. Re: VW T5 Vacuum pump readings
    Pembrokeshire
    22 Post(s)
    it was 100 psi iirc on the old 1.9 pd engines, so imagine it would be about the same.
  5. Re: VW T5 Vacuum pump readings
    Jul 2008
    I've tested the output from the tandem pump and it pulls a good 30inHG. I disconnected every joint and checked that it pulls the same vacuum everywhere with no drop. All is good.
    Across the N75 valve it sucks at about 22inHG to the turbo vanes. I assume this drop is just due to the internals of the N75 valve.
    The valve works as I disconnected it and the turbo was very ineffective and it went into limp mode all the time.
    So now that I've changed the Turbo, MAP, MAF, N75, checked the tandem pump, refurbed the injectors and had a new intercooler, does anybody have any idea what to check next?
    All I can think of is whether it's fuel related.. Is there a way to check the fuel flow to the injectors.
    If the ECU requests fuel but it can't deliver enough how can you check that?
    My understanding of the 2.5 is now limited when it comes to fueling. So when you depress the accelerator, is it the throttle position sensor that then controls the opening of the injectors via the ECU?
    My thinking is that the ECU sees that you want to accelerate, it then expects a certain boost pressure to be reached when more fuel is injected, this isn't reached because the fuel flow is limited for some reason, the MAP(inlet pressure sensor) then never reaches the ECU requested pressure, then it goes into limp mode.
    I've probably got that all wrong...
    Can someone please help?
    I'm at a total loss of why it's so underpowered and goes into limp mode under load!
    Thanks............
  6. Re: VW T5 Vacuum pump readings
    1836 Post(s)
    What is the code number it is generating? Have you done a requested/actual boost graph test in Measuring blocks 011 zones 2 and 3?
  7. Re: VW T5 Vacuum pump readings
    Jul 2008
    I have yes, and the actual boost pressure measured at the MAP is always considerably less than the ECU requested.
  8. Re: VW T5 Vacuum pump readings
    Jul 2008
    PO299 is the code - underboost
  9. Re: VW T5 Vacuum pump readings
    1836 Post(s)
    In Basic Settings 011, the revs are lifted and the N75 cycled, does the VNT actuator move up and down fully and smoothly in this mode? The boost display should change from approx 1000mBar to 1250mBar. If these are OK I would be considering a new genuine AMM but first of all I would do a 0.5Bar system pressure test but not many people have the equipment.
  10. Re: VW T5 Vacuum pump readings
    Jul 2008
    The AMM was also recently replaced for a Bosch which I believe is what VW use and it made no difference unfortunately.
    The high pressure system has also been pressure tested.
    A new turbo was fitted that made no difference, and then some months later another was fitted as it was thought the initial one may have been faulty.
  1. vacuum pump
    By abby1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-12-2014, 02:29 PM
  2. Question Vacuum Pump?
    By geordiestig in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-01-2014, 07:21 PM
  3. How To Exhaust vacuum pump
    By Nemo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-03-2012, 01:19 PM
  4. Vacuum pump (tandem pump)
    By audi_130bhp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 12:44 PM
  5. electric vacuum pump
    By gaz238 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2007, 04:45 PM
