Thread: Some clarification please
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. Re: Some clarification plz!!!!
    #21
    Pembrokeshire
    22 Post(s)
    indeed, yes it could...
  2. Re: Some clarification plz!!!!
    #22
    Apr 2015
    serbia
    Ok kool - thanks again for your help
    Ill give that a go and see what we come up with
  3. Re: Some clarification plz!!!!
    #23
    Apr 2015
    serbia
    Sorry to be a pain, but just re-reading your post re the vacuum test on the servo hose etc - should i do this with car on or off??
    Tnx mate
  4. Re: Some clarification plz!!!!
    #24
    Pembrokeshire
    22 Post(s)
    running..
  5. Re: Some clarification plz!!!!
    #25
    Apr 2015
    serbia
    Sweet tnx
  6. Re: Some clarification plz!!!!
    #26
    Apr 2015
    serbia
    Hey mate,
    Did the vac test with the brake pumping as you mentioned :
    The vac with car on is around the -20inHG (im guessing hg is not the same as mg as you mentioned, but couldn't find a conversion anywhere) and when brake is pumped is drops/lifts to -10inHG. If the brake is pressed faster then it drops/lifts even more almost close to 0....dnt know what this means.
    If you can make any sense of this id like to know what you think..
    Much appreciated
  7. Re: Some clarification plz!!!!
    #27
    Apr 2015
    serbia
    Ps.....it does go bak to -20 when pumping is stopped
  8. Re: Some clarification plz!!!!
    #28
    Pembrokeshire
    22 Post(s)
    i would say that you have a week vacuum pump. i would repeat the test but blank off everything else including the servo so that you can rule out a leak or a faulty servo, then repeat so you are only testing the vacuum pump. in fact, you can remove the cover plate from the tandem pump to see the vac pump. there are 2 metal sprung loaded blades, i bet one is broken or the spring is broken.
  9. Re: Some clarification plz!!!!
    #29
    Apr 2015
    serbia
    This is my version of tandem pump- so just take the front cover off and sus it out??
    Tnx
  10. Re: Some clarification plz!!!!
    #30
    Pembrokeshire
    22 Post(s)
    yeah, basically. one side , nearest the engine is fuel, outside is vacuum, thats how it was on a 1.9 but i think yours is the same. really it should hold 20 all the time and not drop much at all.
  1. Question Oil clarification
    By powerband in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-05-2015, 09:47 AM
  2. Rules of the road - clarification please?
    By fat controller in forum Chat - Completely Off Topic
    Last Post: 23-10-2012, 08:18 AM
  3. Question Part clarification
    By Axios in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-09-2010, 06:55 PM
  4. Service clarification please
    By matthewbob in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-09-2010, 12:44 PM
