Thread: P0401 EGR insufficient flow
  1. Question P0401 EGR insufficient flow
    Jul 2016
    Preston
    Hi everyone new member.
    This concerns a 2007 2.0 TDI diesel PD engine passat.
    Warning light on dash. Got a code reader and it says P0401 EGR insufficent flow detected.
    Took the EGR off cleaned it, and took the plastic cover off the back and mechanically it works fine all gear wheels go round and the little valve opens and closes just fine.
    Re-fitted last night. Cleared the warning light, started the car and the warning light came on again. Engine runs fine. No mis-fire or lumpyness.
    Question is this: Is the EGR electronically fault. Should i buy a new EGR valve ? Or might it be something else that might be causing the fault ??
    Any help most appreciated.
    Paasatwoes
  2. Re: P0401 EGR insufficient flow
    Apr 2016
    Ireland
    The pipes in the EGR system can get clogged up with carbon too, not just the valve, thus restricting flow. If possible remove the pipes and give them a good scrub.
  3. Re: P0401 EGR insufficient flow
    Norfolk
    The ecu does not measure egr flow. It measures MAF sensor flow. The ecu interprets MAF value too high as being egr flow too low and sets code p0401. Most of the time this is correct and the egr needs replacing.
  1. P401 egr insufficient flow
    By Nasif Khan in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-02-2020, 12:01 AM
  2. Audi A6 2.7TDI w. fault code: EGR System - Insufficient Flow - Intermittent
    By MartinCB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-04-2016, 01:26 PM
  3. Insufficient flow MK6, why worked after maintenance?
    By ronnyy in forum Golf MK6 - 2009 - 2013
    Last Post: 10-01-2015, 09:15 PM
  4. 16785 - EGR System: Insufficient Flow
    By chrisgeary in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-11-2011, 10:24 PM
  5. EGR insufficient flow on Golf GT TDI mark v
    By aggie in forum Golf MK5 - 2004 - 2009
    Last Post: 06-07-2010, 01:21 PM
