Thread: 3.0 chain ?
Results 1 to 10 of 17
  1. 3.0 chain ?
    May 2016
    London
    18 Post(s)
    Does this sounds like chain needs doing ?
    audi 3.0 tdi chain rattle ? - YouTube
    2006 Audi A6 3.0TDI quattro sline le mans | Daytona Grey Pearl
  2. Re: 3.0 chain ?
    46 Post(s)
    in my opinion, no.
    you'll only hear it on stone cold start and it literally will be a distinct rattle.
    been there done that got the t-shirt, it was the reason i sold my 2008.
  3. Re: 3.0 chain ?
    May 2016
    London
    18 Post(s)
    Ill do another video tomorrow morning on cold engine
  4. Re: 3.0 chain ?
    Feb 2016
    Hungary
    113 Post(s)
    Quote Originally Posted by niedzial1983 View Post
    I had to replace my timing chain on my former 4F/3.0, but it sounded a lot worse when I started the car. It sounded something like this: Audi a6 3.2 v6 quattro 2005 startup noise before upper chain tensioner replacement - YouTube for a short period of time after the ignition.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  5. Re: 3.0 chain ?
    May 2016
    London
    18 Post(s)
    Here is mine again from the start
    Audi 3.0 chain noise - YouTube
  6. Re: 3.0 chain ?
    Jul 2015
    Staffs
    46 Post(s)
    No. Is it noisier than normal?
    Ian
    A4 B6 Avant Nogaro Blue
  7. Re: 3.0 chain ?
    May 2016
    London
    18 Post(s)
    I didn't notice any change since i bought it a year ago.
    But today i started the car when i had the bonnet up and it seemed loud
  8. Re: 3.0 chain ?
    46 Post(s)
    Of course it's going to sound louder with the bonnet open ...
    0 2 0
  9. Re: 3.0 chain ?
    Feb 2016
    Hungary
    113 Post(s)
    Of course if you open it, then you will miss the sound-proofing. For me, the engine sounds quite normal, however it seems to me, that there could be a little timing chain problem at the very beginning. In my car this sound level was treated as "normal", and I had to replace the timing chain later. However if that sound, which you can hear right after the ignition will be worse, then I suggest to check the engine. To change a timing chain is a costly thing, however it's far cheaper than to replace the engine.
  10. Re: 3.0 chain ?
    May 2016
    London
    18 Post(s)
    Can any of you post a video of the sound where they are not failing ?
  1. Timing Chain
    By Swift3269 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-07-2014, 06:20 PM
  2. Help - Belts or Chain
    By Rusyp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-08-2011, 09:06 PM
  3. chain tensioner
    By barrymorri in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-03-2011, 11:40 PM
  4. 1.2 Cam chain
    By Liftman in forum Ibiza - Cordoba
    Last Post: 04-09-2010, 02:20 PM
  5. timing chain data for fitting new chain
    By stephen gal in forum Ibiza - Cordoba
    Last Post: 26-05-2008, 03:17 AM
