Thread: A6 door catches that don't - again
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: A6 door catches that don't - again
    #11
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Just general description Audi a6 door lock , I took my old one apart and could see nothing worn or loose or damaged
    Sent from my LG-D855 using Tapatalk
  2. Re: A6 door catches that don't - again
    #12
    Apr 2015
    Damascus, Syria
    Hi Stephen,
    " Just general description Audi a6 door lock , I took my old one apart and could see nothing worn or loose or damaged" That's really strange........nothing visibly wrong, yet when replaced, new lock works perfectly. If it was somehow connected to the electrics, we could blame that, but its just a mechanical part.. could also be micro wear through out the lock rather than one or two obviously worn parts of the mechanism. Anyway...I have the same problem on the drivers door, slight pressure only to lock it, anything heavier ... and it just bounces. I tried inserting a screw driver into it, mimicking the action of the striker receiver, and with the screw driver, it works perfectly, 1st stage on safety, and 2nd stage locking. And I would guess that the rear door locks are different,,,, would be to good to be true to have them interchangeable !!!!!! Anyway, I will remove the trim panel and have look at what's happening, but I will have a replacement on hand at this point.
    Thanks for your help Stephen
  1. Passat B7 estate door and boot catches
    By ajpt in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 27-06-2016, 07:38 PM
  2. Door closed. Door handles don't work
    By Kris12 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-11-2014, 08:02 PM
  3. Please Help Mk4 electric door mirrors don't work - switch is seized solid
    By Saladdin in forum Golf MK4 - 1999 - 2004
    Last Post: 18-06-2014, 12:50 AM
  4. Allroad door catches not 'snicking' Grrrrr
    By Fly100 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-01-2013, 08:34 AM
  5. Bonnet catches stuck shut - Polo 2001
    By rgf1 in forum Polo - Derby - Lupo - Fox
    Last Post: 13-03-2006, 03:59 PM
