Thread: Interesting, strange find
  1. Interesting, strange find
    Apr 2015
    serbia
    Hey guys,
    Skoda octavia 2007 BKD 2.0tdi
    Just took my intake of and found this....
    Any idea??
    thanks
  2. Re: Interesting, strange find
    1836 Post(s)
    Has it been losing coolant? BKD's were known for porous ports but only right at the beginning of production, late 2003 early 2004.
  3. Re: Interesting, strange find
    Apr 2015
    serbia
    Thanks for your reply
    Yes it has been losing coolant. Ive changed the egr cooler, coolant cap and still losing. Strangley enough it drops overnight.
    I also had the turbo recon and am getting underboost so dont know if its related
    Is there a way to check the head without removing it??
  4. Re: Interesting, strange find
    1836 Post(s)
    Yes, position the engine so the inlet valves are shut and place a pressure tester onto the coolant bottle and leave it at 1Bar overnight, then check to see if there is water behind the valves.
  5. Re: Interesting, strange find
    Apr 2015
    serbia
    Ok kool tks ill do that.
    On another note while ive got you, as mentioned ive got the p0299 underboost code after installing a new/reco turbo.
    So far changed : MAF, MAP, EGR cooler, EGR valve cleaned and vacuum checked, Turbo actuator new and tested, Vacuum lines hold vacuum. Ive visually checked the intake pipes and they seem ok, yet to do boost leak test.
    1st and 2nd gear pulls ok (not great) and then in 3rd hits limp mode at higher rpm, no engine light. If i drive it in limp mode it pulls like crap up until 2000rpm then for a brief second it pulls and then backs of again - when it backs off a whine, spool sound is heard, as if all the pressure that was built gets pushed out somewhere.
    To add - my tandem pump was leaking where it connects to the head
    so i just changed the gasket, no more leaks but maybe internally an issue. I dont know how or if its related with vacuum or what not.
    Apologise for the lengthy post just need a point in the right direction.
    Tnks
  1. My A4 (not that interesting)
    By croakey in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-07-2013, 07:42 AM
  2. Very interesting article, long but interesting
    By ben0069 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-04-2012, 09:30 PM
  3. Please Help Interesting one!!!
    By MancunianMan in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-07-2010, 02:18 PM
  4. Anything interesting?
    By devsgolf in forum Chat - Completely Off Topic
    Last Post: 08-08-2008, 02:10 PM
