Thread: Gearbox Malfunction
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Gearbox Malfunction
    #11
    Dec 2015
    London
    13 Post(s)
    Warranty Invoice only has that description I gave within quotes, no numbers
  2. Re: Gearbox Malfunction
    #12
    Oct 2016
    Grays
    Audi A7 sline 3.0 tdi quatro
    i have same problem gear box mal function.after 2 h is goon,i had for 2 times,than it come up on M25 ,,Revers not working,you can vontinu driving, but not working any moor any of the shifts.I realized that a hose from gearbox was broke and lost the oil from gearbox.the recuvery guy told me is the 2 car in 24/h same problem.
    do you think guys the gearbox is still good? If i change the pipe and refuel with oil?
    is not anymoor in guaranty.
    thank you
  3. Re: Gearbox Malfunction
    #13
    Jun 2016
    Szalkszentmarton
    Last March i got an additional immo installed. After that sometimes it might have generated some faults in more moduls when i jumped out of car for a while with immobiliser's card in pocket and engine was running. However sometimes i tried or succeded to clear the fault codes although maybe not right after they were generated. Around may-june i got first time the same malfunction message as seen on first page. At first no other symphtom then loss of power and engine even stopped for some minutes. A repairer found no special code and thought it might be due to lower voltage of battery (11,7V that time). Then there was no malfunction message till december when it again stopped some times but restarted then didn't start at all at the end in cold weather. I thought at first it's due to the battery of car as i even saw 11,2V somewhere in VCDS. I changed battery to new one but still not started when i realised that the battery of the immo card also died therefore i switched off immo and engine ran. Some fault codes might have remained although i tried to clear. Went on a tour and gearbox malfanction message appeared again while changed gear more times, lost power and sometimes stopped. Then i got new battery for immo, i switched it on then succeded to clear codes in "02 autotrans". Since then i haven't driven a lot. Do you think my malfunction message was generated due to the immo and solved now if it doesn't make new codes or the problem can remain and i can expect more messages?
  4. Re: Gearbox Malfunction
    #14
    Jun 2016
    Szalkszentmarton
    I got the additional immobiliser uninstalled but the gearbox malfunction message still remains. I was even at an audi service and they say the problem they also detected is the selector lever sensor and a "pressure regulator valve" (i don't know if it equals to "valve for transmission fluid cooler" as per the code below. I'm confused as they said separate prices to these items but an other mechaniker was speaking about a kind of panel that costs ca 500 eur and includes both items acc. to him. But if the change doesn't eliminate the problem then the change of the electronics should solve the issue. That costs ca. 2500 eur. What do you recommend to do? Should i maybe rather buy a complete used gearbox for ca. 1000 eur? I want to sell the car so the cheapest solution i'd prefer but this problem should be solved on the other hand. Thanks for your help.
    15902863 10215235649067370 2122644524 o - szr_3_14 - indafoto.hu
    15877830 10215235645307276 739274072 o - szr_3_14 - indafoto.hu
    15856980 10215235636507056 2078487568 o - szr_3_14 - indafoto.hu
    15857875 10215235650947417 30387619 o - szr_3_14 - indafoto.hu
    15878372 10215235630026894 1230012628 o - szr_3_14 - indafoto.hu
  5. Re: Gearbox Malfunction
    #15
    Dec 2015
    London
    13 Post(s)
    does anyone know what kind of clutch the s-tronic has?
    Is it an actual dual dry clutch mechanism operated by electronics or is it some kind of oil based wet clutch?
  1. Audi A6 2012 - Gearbox Malfunction: you can continue driving
    By Audia63.0 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-11-2017, 11:29 AM
  2. Replies: 2
    Last Post: 12-08-2016, 07:35 PM
  3. Bulb malfunction
    By Dooey in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-05-2015, 03:58 PM
  4. Please Help alarm malfunction
    By Dave Anderson in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-08-2009, 06:34 AM
  5. Multiple A4 malfunction!!
    By stuart4rosehill in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-06-2009, 09:38 AM
