Thread: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
Results 1 to 10 of 13
  1. Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Jun 2016
    Scunthorpe
    Hi, i've had my Emissions light on for a couple of months now and finally got round to getting VCDS, previously i have taken off the anti-shudder valve and the egr and given them a good clean which made no difference to the Emissions light, i plugged my VCDS cable in and heres the fault that it threw up:
    1 Fault Found:
    008201 - Intake Manifold Flap; Bank 1
    P2009 - 000 - Short to Ground - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 12
    Reset counter: 255
    Mileage: 157603 km
    Time Indication: 0
    Date: 2010.11.06
    Time: 00:03:18
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Load: 100.0 %
    Lambda: 99.4 %
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 77.4°C
    Readiness: 1 1 0 0 0
    I've had a look round on the forums and some people are saying the whole intake manifold has to be replaced along with the actuator and others are saying it can be that the swirl flaps are blocked up or the fuse has gone, can anyone enlighten me as to which fuse this is on the B6 CR passat? and also if anyone has any other advice before i go out and buy a new intake manifold?
    thanks in advance!
  2. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Jul 2007
    glasgow
    35 Post(s)
    have you changed the sensor ?
    Scrapyard a good place to go as well .............
    Try reading this and checking your wiring 008213 - Intake Manifold Flap Position Sensor (Bank 1) My Solution.
    you could also try youtube
  3. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Norfolk
    Have you checked the wiring in case the code is correct and you have a short to ground
  4. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Jun 2016
    Scunthorpe
    I've not changed the sensor as the fault is with the motor itself by the looks of things and I've seen other people who have posted the fault that specifically states the position sensor.
  5. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Norfolk
    The error says short to ground so you have a "short to ground" Fix the short
  6. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Jun 2016
    Scunthorpe
    I had a quick look last night and of the 5 pins in the connector, 4 of them had continuity to ground, does anyone have a wiring diagram? Ive checked my haynes manual but there isnt one for the intake system.
  7. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Jun 2016
    Scunthorpe
    OK so I found the short, the motor inside the intake manifold flap actuator has a direct short to its casing, by the looks of it its sealed for life too so I can't check the internals.
    The motor has the following on the side:
    12v
    A2C53241415
    3J2502
    and the part number for the actuator is:
    03L 129 086 v120
    Anyone know if I can just buy the Motor from somewhere or will I have to buy the full actuator?
  8. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Jun 2016
    Scunthorpe
    To follow up, as a temporary fix I have put a thin layer of high temperature resistant flame retardant electricians tape around the motor to prevent it from touching the actuator housing and then tested for shorts to the casing which there weren't, I then applied a 12v DC source each way to the terminals on the motor and it rotated fine each way.
    Fitted the whole thing back in the car and cleared the fault codes and then used VCDS to adapt the intake manifold flap/runner and it worked fine. Took the car for a drive and no more emissions warning light.
    Again, this is only a temporary fix to carry me over until I can get round to going to a scrapyard or buying a new actuator.
  9. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Sep 2016
    windsor
    There are some manifold repair kits avilaible from this website manifoldskitsuk.co.uk
    I have purchased repair kit for 2.7 tdi from them but they also have kits for 2.0tdi.
    1 1 0
  10. Re: Intake manifold flap issue Passat B6 58 plate 2.0 tdi CR DPF 140PS
    Mar 2019
    Norwich
    Quote Originally Posted by Majorlook View Post
    Hi I have the same issue as you with the 2009 short circuit fault mine even sparked today when it made contact!
    Can you tell me did a new motor fix the issue?
  1. Intake Manifold Flap
    By Borab0y in forum Golf MK5 - 2004 - 2009
    Last Post: 14-02-2015, 09:33 PM
  2. V157 Intake Manifold Flap Issue
    By willc1985 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-02-2014, 12:29 PM
  3. Please Help 2.0 tdi (140) mass air flow &motor for intake manifold flap
    By masbs4 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-06-2013, 08:18 PM
  4. Replies: 12
    Last Post: 24-11-2012, 12:41 PM
  5. v6 tdi intake manifold flap fault
    By andreia in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2012, 01:21 PM
