Thread: Q7 (4M) Coding
Page 49 of 70 FirstFirst ... 39474849505159 ... LastLast
Results 481 to 490 of 696
  1. Re: Q7 (4M) Coding - Last Updated 16-08-2018
    Mar 2010
    37 Post(s)
    228 Post(s)
    I think it's a security thing yeah. Engine running + keys nearby.... Make your own mind up.
  2. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jun 2017
    Croatia
    Hi Retom,
    Are you able to activate/deactivate easy entry for passenger seat on mmi?
    Today I activate option as Andy suggested in module 06 and passenger seat is moving back but I don't have option to turn it ON/OFF on mmi.
    Thank you
    Marko
  3. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jan 2018
    Warsaw
    65 Post(s)
    No, we can't activate/deactivate easy entry separately for passenger seat on MMI. On MMI you can only activate/deactivate the whole system: steering wheel, driver's seat and passenger seat - all together. I am curious how it is solved in new Q8 since as I have noticed this model has already factory set easy entry also on both seats, not only on steering wheel column as in our Q7s. I hadn't so far a chance to dig so deep in Q8 software. If it is possible in Q8 perhaps we will be able to activate it also in our cars as it is the same platform.
  4. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jun 2017
    Croatia
    Thank you on reply!
    Can you send me your coding of modules 06 & 36, because I can't get both seats working in parallel.
    When I code easy entry on passenger seat than seat is always moving no matter if easy entry on driver seat is ON or OFF.
  5. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jan 2018
    Warsaw
    65 Post(s)
    Hi Marko,
    Sorry, I was mistaken. I have checked in my car, passenger seat easy entry I can disable only via coding as in your car. I believe that there is a possibility to do it also via MMI. When I will have more time I will do some experiments and I will let you know if I am successful. It could be a need to do some coding also in Module 09 Central Electrics to call the passenger easy entry screen on MMI.
    Perhaps our guru Andy has an idea?
  6. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jun 2017
    Croatia
    Thank you on reply.
    We have the same issue with it.
    There is maybe some option for passenger seat in 09 module.
  7. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    I've been through the whole of 09 and nothing jumps out for Passenger Seat Easy Entry Option for the MMI
    If anywhere it will be in 06 or a slim chance in 52.
    It makes sense we can't find it.. Easy Entry on a Passenger Side doesnt make sense does it?
  8. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jan 2018
    Warsaw
    65 Post(s)
    Andy, our cars have couple of useless gadgets. This is probably one of them..... but as usual it is nice to have it .
  9. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Sep 2018
    norway
    Can someone tell me how to lower the q7 4m 10-15mm with VCDS or similar?
  10. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Apr 2011
    edinburgh
    Quote Originally Posted by audi_norway View Post
    Not able to do this from VCDS.
    But I have seen these kits:
    https://rover.ebay.com/rover/0/0/0?m...2F112526574438
    Lowering linkages for Q7 4M
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
