Thread: Q7 (4M) Coding
Page 63 of 63 FirstFirst ... 1353616263
Results 621 to 627 of 627
  1. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Feb 2016
    Ljubljana
    Quote Originally Posted by andyhud007 View Post
    Thanks Sander, appreciate you sharing this info
    You are more than likely right, but in the UK its all enabled as standard which is why I dont think we picked up on these extra adaptation channel changes
    At the most though you should only need to active these 2:
    Car_Function_Adaptations_Gen2-menu_display_seat_configuration
    Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_hig h
    Not the other 3.
    Thanks for sharing
    Andy
    Hello,
    I also checked those adaptation and it was all set to enable, but still get no easy entry funciton (I am trying to code my seats without any memory funcition on the car eather on driver or passenger side).
    Hope there is an option to enable it on my car, since easy entry function lika already said randomly works on the passenger side (some times it is not working at all, some times the seat only comes back, but not return to the original position, sometimes it works like it should, going back and returning to the original position).
    Have a great day.
  2. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Apr 2020
    Perth, Australia
    Hello all & thanks Andy for the thread.
    I have a 2019 Touareg III running on the same MLBevo platform in Australia , and have hit the same brick wall regarding TSR (VZA) enablement using only VCDS with HEX-NET.
    I am going to invest in a VCP now to do the parameterisation of the A5 camera.
    Some successful coding I have done so far as follow, which may be of interest to some?
    Module Byte Bit Desc Result
    09 Cent. Elect. 02 02 drl_break_active DRL's switch off when in P & Elec. brake on
    09 Cent. Elect. 02 03 sl_at_drl,active Rear tails on with DRL
    46 Central Conv. 21 05 high brake light to indicate virtual pedal trigger (emergency braking) also momentery on with foot gesture boot opening
    5F Information Electr. 23 01 Initial disclaimer _on switch off "nag screen" …..please follow traffic regulations at all times.
  3. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Apr 2020
    Perth, Australia
    Forgot this one too.........
    13 Auto Dist. Reg 02 05 Overtaking right prevention Switches off RH Lane front vehicle detection / ACC allows undertaking
  4. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Mar 2010
    31 Post(s)
    208 Post(s)
    Quote Originally Posted by evadT3CR View Post
    5F Information Electr. 23 01 Initial disclaimer _on switch off "nag screen" ..please follow traffic regulations at all times.
    Thanks for sharing. Yes you need vcp for VZE. Good luck.
  5. Re: Q7 (4M) Coding
    May 2020
    usa
    Seat Symmetry + Passenger Seat Control
    Description: For Q7 (4M) cars that have BOTH Driver and Passenger memory seats installed (with the buttons in the doors) you can make both the drivers seat and passenger seat "line up" so they are symmetrical. In addition, you can move the passenger seat using the seat movement buttons on the drivers seat. This change enables these features if you have ONLY Driver Memory Seat installed
    Notes: Not been tested on Q7 4M cars that have neither driver or driver/passenger memory seats installed but it should work. You need to do the SAME coding in Modules 06 and 36.
    Usage: Once coded, go into MMI, Car / Vehicle Settings / Seats. A new option for Passenger Seat will have appeared. There will be 2 options inside. One to line both front seats up together, and the other to move the passenger seat with the driver seat movement buttons
    Risk: Low
    Coding:
    1. Module 06 - Passenger Seat Module & Module 36 - Driver Seat Module
    2. Coding
    3. Long coding
    4. Long coding helper (VCDS)
    5. Byte 2
    6. Tick "Bit 5"
    7. Byte 6
    8. Tick "Bit 1"
    9. Exit
    10. Do It
    Coding Screenshot 1
    Coding Screenshot 2
    Screenshots of Seat Symmetry Enabled
    Video of Seat Symmetry working without Passenger Memory Seat buttons installed
    Attachment 31905
    I can't find module 6 in my 2018 Q7. Any idea why?
  6. Re: Q7 (4M) Coding - Last Updated 22/11/2016
    May 2020
    usa
    you ever figure out where module 6 can be found? I have the same issue.
  7. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Mar 2010
    31 Post(s)
    208 Post(s)
    Audi changed the seat wiring from 2018 models onwards. If you didn't order passenger memory seats from factory then they didn't install the seat module under the seat.(module 06)
    Take a look under your driver seat. On the underside of the seat you'll see a box with plugs in it. (Module 36). Now go look under your passenger seat, there won't be one.
    Andy
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
free web
stats
