Thread: Q7 (4M) Coding
Page 48 of 55 FirstFirst ... 384647484950 ... LastLast
Results 471 to 480 of 548
  1. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jun 2017
    Croatia
    Thank you!!!
  2. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jan 2018
    Warsaw
    9 Post(s)
    I dit it. It's working! I didn't have to code 09 since I have electric steering column with memory and it was already factory coded. But after coding 36 (driver seat) the full Easy Entry started to work. Driver's seat also moves back.
    Thanks Andy.
  3. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Mar 2010
    21 Post(s)
    Quote Originally Posted by Retom View Post
    Thanks Andy.
    Pleasure!
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Chger | Homelink | Soft Door Close | Heat+Snd Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Susp | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  4. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jun 2017
    Croatia
    Hi Andy,
    Is it possible to code easy entry for passenger seat?
    Regards
  5. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Mar 2010
    21 Post(s)
    Quote Originally Posted by Timar View Post
    Hi Andy,
    Regards
    Might be, but not tested. Try the same Bit that I've listed for Module 36 but do it in module 06 which is the passenger side
    Andy
  6. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jun 2017
    Croatia
    Thank you, will try!!
    Marko
  7. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jan 2018
    Warsaw
    9 Post(s)
    .....and let us know the results.
  8. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Jan 2018
    Warsaw
    9 Post(s)
    Quote Originally Posted by andyhud007 View Post
    Andy
    I have tested it in my car. It also works for passenger seat. As you Andy suggested: module 06 the same bit. Please note that I have the passenger seat with the memory. No idea if it works also when you have the seat without memory.
  9. Re: Q7 (4M) Coding
    Jun 2017
    Croatia
    Hi Andy,
    I Enabled ability to lock car with Engine running and noticed that my Q7 can be locked via the lock button on the keyfob and the button on the door (I have convenience key), but can't be unlocked via sensor on door handle (convenience key). It can be unlocked only via unlock button on the keyfob.
    Do you know is it normal behavior not to be able to unlock car via sensor on the door handle?
    Thank you!
    Regards
    Marko
  10. Re: Q7 (4M) Coding - Last Updated 16-08-2018
    Mar 2010
    21 Post(s)
    It's normal behaviour when the engine is running. Correct.
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 27-10-2015, 06:07 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
