Thread: Q7 (4M) Coding
Page 11 of 70 FirstFirst ... 9101112132161 ... LastLast
Results 101 to 110 of 696
  1. Re: Q7 (4M) Coding
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by Papereyes View Post
    Great work mitchfin. Just need to grab a coder! Let me know how u get on with lane assist
    This is really interesting this one.
    To my knowledge High Beam Assist is standard on UK versions of the Q7 no? Even with standard headlights?
    Mitchfin - Is it not the case on US cars?
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  2. Re: Q7 (4M) Coding
    Mar 2016
    Budapest, Hungary
    39 Post(s)
    Here in Hungary it is a 150 pound option.
  3. Re: Q7 (4M) Coding
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by anemeth View Post
    Thanks Anemeth, I just checked the latest UK brochure and High Beam Assist is standard on S-Line/SQ7 and E-tron models. Its £145 extra on SE
    Andy
  4. Re: Q7 (4M) Coding
    Sep 2016
    Utah
    This will work for B9 A4 as well, but no it is not standard in the NAR region, it is only available via the driver assist package $1800 on A4 and $2400 on the Q7.
  5. Re: Q7 (4M) Coding
    Sep 2016
    Utah
    Here is the coding and adaptations that I used to activate Audi Active Lane Assist, I am not making any promises or assuming responsibility, code at your own risk, But it worked perfectly for me. I do get a few faults but I think it is due to me trying to activate Traffic Sign Recognition.
    You will get a few bings from your car about Pre Sense Malfunction, these will all go away once you are done. This will activate the self steering, steering wheel vibration, and lane crossing warning. Do all the coding then do adaptations.
    ALL Coding:
    A5 - Frt Sens. Drv. Assist
    HC>Active | Byte 16>Bit 7
    STA>Active | Byte 16>Bit 5
    EFP>Active | Byte 12>Bit 3
    17 - Dash Board (One of these may already be on, make sure both are)
    Lane Assistant>Active | Byte 4>Bit 6
    Lane Change Assistant>Active | Byte 5>Bit 3
    09 - Central Electrics
    Heading Control Config>heading_control | Byte 35>Bit 0
    44 - Steering Assistance
    Heading Control Assistant>Active | Byte 2>Bit 7
    ALL ADAPTATIONS:
    5F - Information Electronics
    Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning = Set Value to “Activated”
    Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning_over_threshold_high = Set Value to “Activated”
    Car_Function_List_BAP_Gen2>LDW_HCA_0x19> Set Value to “Activated”
    Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus> Set Value to “Terminal 15”
    BAP Personalization = Set Value to “Not Activated”
    Personalization of lane dept. warning Cl. 15 on = Set value to “Last Setting”
    System mode, lane depart. warn, = Set Value to “Selection via menu”
    Switch-on condition, lane depart. warn. = Set value to “On” (I had to toggle this as this is the final step that I believe mimics pressing the button to actually activate it. You know it was successful when the Lane markings show up in the VC)
    You can tweak the vibration intensity, warning time, and steering effort in the A5 adaptations.
  6. Re: Q7 (4M) Coding
    Mar 2016
    KEnt
    22 Post(s)
    Quote Originally Posted by Mitchfin View Post
    ALL Coding:
    ALL ADAPTATIONS:
    Great job Mitch!!! Does that give you pre sense front as well?
    Although have to be honest and bit intimidated to do the above.
    Might wait a bit before i attempt any of this!
  7. Re: Q7 (4M) Coding
    Sep 2016
    Utah
    Pre Sense front is standard on all 2017 Audis in NAR, so make sure you have the camera before doing this, but my car is already coded for Pre Sense Front
  8. Q7 (4M) Coding
    Mar 2016
    KEnt
    22 Post(s)
    Thanks Mitch which camera we referring to the one in the windscreen. I have pre sense city (std) and pre sense (rear). I also have a camera in the front four rings
    Bit of a newbie for this coding stuff so may need to curb my enthusiasm before I brick my Q7
  9. Re: Q7 (4M) Coding
    Sep 2016
    Utah
    Yes, I believe all cameras are the same on this generation, so you should theoretically be able to enable the Forward Collision Warning (FCPW in the coding)
  10. Re: Q7 (4M) Coding
    Mar 2010
    37 Post(s)
    228 Post(s)
    Coding Updated. Switch off speed for park assist cameras.
    0 2 0
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
