Thread: A4 Avant 2.4SE Yr 2000 Engine circuits
  1. Unhappy A4 Avant 2.4SE Yr 2000 Engine circuits
    Kombiwagen Guest
    I am currently dealing with a suspected intermittent ignition fault which results in failure to start very infrequently. I am having great difficulty in acquiring the circuit diagrams for the engine systems eg ignition, fuel pump, engine management etc. I have an Emanual which is an Audi original but this only contains "current flow diagrams" which are basically chassis electrics only and not relevant. I cannot get anywhere with the diagnosis without said circuits and also component location information eg relays, lhs & rhs footwell connector panel mappings so that I can trace through the relevant circuitry. I suspect water corrosion of connectors is the root of it but which ones to look at?
    Can anyone suggest a complete and comprehensive source for this information please?
    Many Thanks for anything at all!
  2. Re: A4 Avant 2.4SE Yr 2000 Engine circuits
    Mar 2016
    Minervois, France
    53 Post(s)
    If you want to splash out on a pretty comprehensive manual, get the Bentley Audi A4 Service Manual, 1996 to 2001 1.8T and 2.8, published by www.bentleypublishers.com .
    It covers US models, which are pretty much the same as European, and has masses electrical circuit daigrams. Service instructions are not as detailed as Haynes' manual, but more comprehensive.
    I got my hard cover copy on Amazon UK for £42.20, and also the Haynes manual for 1p !
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: A4 Avant 2.4SE Yr 2000 Engine circuits
    Kombiwagen Guest
    Thanks for your suggestion I will follow up the Bentley offering. I was aware of it but sceptical about its coverage and applicability. I already have the Haynes 1.8/2.8 you mention and this is no where near comprehensive enough. I think it likely that only the VAG original circuits will do the job and these may well be embedded in a diagnostic software suite. If so its end game! I also have the O/L EManual people promising to attempt to source the circuits. We shall see. Many thanks for your help.
  4. Re: A4 Avant 2.4SE Yr 2000 Engine circuits
    Mar 2016
    Minervois, France
    53 Post(s)
    Just realised you have the 2.4 (V6?) engine, which doesn't seem to be covered by any Bentley manuals. The wiring diagrams might be valid, but a bit expensive to buy just to find out.
  5. Re: A4 Avant 2.4SE Yr 2000 Engine circuits
    Kombiwagen Guest
    Quote Originally Posted by FrenchAudi View Post
    Yes that's right a 2.4 V6 which seems to be a made in small numbers model. For my purposes, its an ideal donkey with a bit of class! Problem is in recent months its become as stubborn as an ***!
    The Haynes manual information suggests that there is a lot of commonality with the US 2.8 version. However the relevant circuit diagrams are for the 2. 8 VW version with a note saying Audi circuits are similar. So I'm effectively twice removed from exact specific to model information.
    The search continues Captain, said Mr Spock.
  1. Replies: 1
    Last Post: 08-01-2014, 07:37 PM
  2. A4 Avant B7 2.0 130 TDI engine misfire/stutter 1800-2000 rpm
    By flub136 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2013, 07:26 PM
  3. ESP / Parking Brake fault (2006MY 2.4SE Avant)
    By boltona in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-01-2013, 08:01 AM
  4. 2000 Audi A4 B5 Avant 1.8
    By MarkieG139 in forum New Member Introductions
    Last Post: 04-12-2012, 07:44 PM
  5. A4 Avant 2000 suspension
    By Grover2000 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2011, 04:03 PM
