Thread: Can a High Pressure Fuel Pump just fall off?
Results 1 to 10 of 17
  1. Can a High Pressure Fuel Pump just fall off?
    Oct 2014
    High Wycombe
    Hello All
    I have a 2005 Audi Avant 2.7tdi with 129K miles and a number of problems - limp mode with glow plug warning light and emissions warning light.
    I've just had the glow plugs and inlet manifolds changed over and while doing the job it was clear that the bolts form the high pressure fuel pump had come loose and the unit was moving around on it's brackets.
    In January 2015 MDM replaced a broken bracket and removed a broken stud and fixed the issue with new audi parts however in just over a year all the bolts have come loose.
    https://youtu.be/u4VOGOBj_BQ
    I have search the internet and this forum but not found any mention anywhere.
    Is this a common issue with Audi HP Fuel Pumps?
  2. Re: Can a High Pressure Fuel Pump just fall off?
    Oct 2014
    High Wycombe
    OK after a little searching around I found "2004 - 2006 the crankshaft vibration damper was poorly produced"
    Excuse my ignorance but does the same belt for the crankshaft to the fuel pump (as well as alternator, water pump, power steering pump and air conditioning compressor)?
    It may well explain why the original problem with the HPF pump i.e. a broken bolt and cracked bracket might have happened. And why the bolts have come loose again.
    thanks
    Matt
    thanks
  3. Re: Can a High Pressure Fuel Pump just fall off?
    May 2014
    Darlington
    78 Post(s)
    That a is a different belt.
  4. Re: Can a High Pressure Fuel Pump just fall off?
    Jul 2013
    76 Post(s)
    If the threads to the bolts holes are worn then the pump could fall out especially if the bolts were over tightened when fitted.
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: Can a High Pressure Fuel Pump just fall off?
    Oct 2014
    High Wycombe
    Quote Originally Posted by B5NUT View Post
    thanks for clearing that one up, shame I thought I may have hit on the answer.
  6. Re: Can a High Pressure Fuel Pump just fall off?
    Oct 2014
    High Wycombe
    thakns for the input, I will suggest on sorting it out they use threadlocker cheers
  7. Re: Can a High Pressure Fuel Pump just fall off?
    May 2007
    Tipp/Cork - Ireland
    Hi there,
    Sorry I know this is an old thread but I have the same problem and its driving me insane!
    I see the OP is no longer active on the forum but am wondering if anyone else has had this..? Mine has come loose twice now and its such a pity as otherwise I am loving the car! ('06 A6 2.7Tdi Saloon BPP Engine)
    If anyone has some advice I would be really grateful!
    Many thanks
    Denis
    2006 A6 2.7Tdi Quattro Saloon BPP Engine
  8. Re: Can a High Pressure Fuel Pump just fall off?
    May 2014
    Darlington
    78 Post(s)
    I would get new bolts and apply thread lock, that should resolve the issue.
  9. Re: Can a High Pressure Fuel Pump just fall off?
    May 2007
    Tipp/Cork - Ireland
    Hi B5NUT,
    Sorry long time to reply, thanks for suggestion.
    I have pump back on car, but have only driven it rarely in the past while. I originally thought there was vibration elsewhere that was causing the pump to shake loose and fall off but after looking at it again with some friends, I have to accept it could be the pump itself. When I had the car in an engineering/fab shop to get new sleeve and fasteners welded/drilled onto the engine, he said he thought the damper pulley and belt pulley were not running true, and this could be caused by play in the shaft etc. (He put a dial runout gauge onto the pulleys while the pump was held in a bench vice).
    So to cut a long story short I am getting a 2nd hand pump and should be able to fit it next week. Yes theres a risk with anything used, but in general the CP1 pumps seem to have few issues...
    I have a Vag Com cable coming from Gendan also, and have emailed Ross Tech on how I might be able to code in a different pump. I will use new bolts and thread lock when I fit it.
    BTW to B5NUT - your build thread was absolutely EPIC, I am hoping to carry out a few mods similar to yours!
    Denis
  10. Re: Can a High Pressure Fuel Pump just fall off?
    1836 Post(s)
    Dengsx, your 2.5TDI uses a different pump system, a so called VEP unit (VP44) and the other cars in this thread are common rail with a single output high pressure fuel pump.
  1. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  2. Audi B7 A4 2.0TFSI Quattro High Pressure Fuel Pump and Camshaft Failure
    By hal402 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-09-2013, 10:31 AM
  3. High Fuel Pressure specified vs actual
    By busandcamper in forum VCDS - Help Requests
    Last Post: 08-12-2012, 12:26 AM
  4. High pressure Fuel Pump Problems on 1.6 TDI
    By bdb in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2010, 10:25 AM
  5. High pressure fuel pump replacement I THINK?
    By MathewRB in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2008, 09:16 PM
