Thread: Can a High Pressure Fuel Pump just fall off?
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Can a High Pressure Fuel Pump just fall off?
    #11
    May 2007
    Tipp/Cork - Ireland
    Hi Crasher,
    Sorry my signature was out of date. I have changed it now to show my current car - 2006 A6 2.7TDi Quattro Saloon BPP Engine.
    2006 A6 2.7Tdi Quattro Saloon BPP Engine
  2. Re: Can a High Pressure Fuel Pump just fall off?
    #12
    16 Post(s)
    388 Post(s)
    I have never seen one of those come adrift but crank damper (or is it dampener?) failure is still a problem on the 2.7 even with the updated part and the resonance from this certainly could make the pump come loose.
  3. Re: Can a High Pressure Fuel Pump just fall off?
    #13
    May 2007
    Tipp/Cork - Ireland
    Thanks Crasher.
    Can I test this damper for failure - e.g. try and wobble it to see if any play in it? Maybe you have to remove the belt to test it properly - and then might have to unbolt front slam panel to get access to it, or maybe it can be done from underneath...
    Funny thing is I have always had a little vibration on the car, especially at motorway speeds. Up to now I thought it was the wheels or tyres, but have replaced all of those in last few weeks. If it turned out that the crank damper was faulty, it would explain a lot of my issues!
    Den
  4. Re: Can a High Pressure Fuel Pump just fall off?
    #14
    16 Post(s)
    388 Post(s)
    Sometimes you can see it wobble but testing it for movement means removing the belt tension which means a strip down.
  5. Re: Can a High Pressure Fuel Pump just fall off?
    #15
    May 2007
    Tipp/Cork - Ireland
    Thanks Crasher I will test it for movement asap
    Den
  6. Re: Can a High Pressure Fuel Pump just fall off?
    #16
    Dec 2007
    Dudley, West Midlands
    Ive had my pump bracket snap twice on my a6 2006 3.0. Audi now tell me the part is on back order, but i would check for broken brackets holding the pump, my alloy bracket snapped at 5he bolt hole on top of the engine screwing down. And rear tin bracket had also snapped.
    Fuel pipe fracture was the 1st i new about it.
    Regards Dean Warren. VCDS owner/user
    Audi A6 Avant 2.5 TDi (AAT 115BHP) 305k Sold
    A6 180 sport 2.5 TDi Quattro Avant 2001. Half Leather 160K New Cams Fitted @ 154K
    A6 C6 3.0 TDi Quattro S-Line Avant with Exclusive Leather SatNav Bluetooth AMI LED and Xenon's
  1. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  2. Audi B7 A4 2.0TFSI Quattro High Pressure Fuel Pump and Camshaft Failure
    By hal402 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-09-2013, 10:31 AM
  3. High Fuel Pressure specified vs actual
    By busandcamper in forum VCDS - Help Requests
    Last Post: 08-12-2012, 12:26 AM
  4. High pressure Fuel Pump Problems on 1.6 TDI
    By bdb in forum Golf MK6 - 2009-2013
    Last Post: 17-12-2010, 10:25 AM
  5. High pressure fuel pump replacement I THINK?
    By MathewRB in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2008, 09:16 PM
