Thread: Can a High Pressure Fuel Pump just fall off?
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Can a High Pressure Fuel Pump just fall off?
    #11
    May 2007
    Tipp/Cork - Ireland
    Hi Crasher,
    Sorry my signature was out of date. I have changed it now to show my current car - 2006 A6 2.7TDi Quattro Saloon BPP Engine.
    2006 A6 2.7Tdi Quattro Saloon BPP Engine
  2. Re: Can a High Pressure Fuel Pump just fall off?
    #12
    12 Post(s)
    222 Post(s)
    I have never seen one of those come adrift but crank damper (or is it dampener?) failure is still a problem on the 2.7 even with the updated part and the resonance from this certainly could make the pump come loose.
  3. Re: Can a High Pressure Fuel Pump just fall off?
    #13
    May 2007
    Tipp/Cork - Ireland
    Thanks Crasher.
    Can I test this damper for failure - e.g. try and wobble it to see if any play in it? Maybe you have to remove the belt to test it properly - and then might have to unbolt front slam panel to get access to it, or maybe it can be done from underneath...
    Funny thing is I have always had a little vibration on the car, especially at motorway speeds. Up to now I thought it was the wheels or tyres, but have replaced all of those in last few weeks. If it turned out that the crank damper was faulty, it would explain a lot of my issues!
    Den
  4. Re: Can a High Pressure Fuel Pump just fall off?
    #14
    12 Post(s)
    222 Post(s)
    Sometimes you can see it wobble but testing it for movement means removing the belt tension which means a strip down.
  5. Re: Can a High Pressure Fuel Pump just fall off?
    #15
    May 2007
    Tipp/Cork - Ireland
    Thanks Crasher I will test it for movement asap
    Den
  1. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  2. Audi B7 A4 2.0TFSI Quattro High Pressure Fuel Pump and Camshaft Failure
    By hal402 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-09-2013, 10:31 AM
  3. High Fuel Pressure specified vs actual
    By busandcamper in forum VCDS - Help Requests
    Last Post: 08-12-2012, 12:26 AM
  4. High pressure Fuel Pump Problems on 1.6 TDI
    By bdb in forum Golf MK6 - 2009-2013
    Last Post: 17-12-2010, 10:25 AM
  5. High pressure fuel pump replacement I THINK?
    By MathewRB in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2008, 09:16 PM
