Yes AT et al I see whats happened now....found this:
"During MMI updates this menu can get “lost” and become inaccessible. It disappears from the menu list. My car had been updated to the latest version (5570) prior to me purchasing it but typically this menu was missing. The easiest way to bring this menu back is via the service menu – but it’s also possible to do this with VCDS if you’re service menu is disabled."
Via the service menu:
  1. Press and hold the [SETUP] and [CAR] buttons simultaneously for about four seconds
    Well that didn't work so guess my service menu is now disabled and as dan2485, you and others have mentioned I probably needs VCDS to sort this out. Worth a shout out anyway thanks people for your input.
    How to re-enable the Instrument Cluster menu | The Real Transporter
