Thread: Auxiliary Heater
  1. Auxiliary Heater
    Mar 2009
    Cheshire
    Can anyone offer any advice on the following from my VCDS scan. I wasn't even aware I had an Auxiliary Heater in my car. Maybe this is why the code is being thrown out?
    Address 08: Auto HVAC Labels: None
    Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
    Component: KLIMAAUTOMAT 016 0300
    Revision: 00000025 Serial number: 00000000045434
    Coding: 1067009
    Shop #: WSC 02311 785 00200
    VCID: 1B3FCF2CDA5B01C6611-804E
    1 Fault Found:
    01207 - Control Module for Auxiliary Heater (J364)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 156110 km
    Time Indication: 0
    Date: 2016.05.04
    Time: 10:22:57
    Freeze Frame:
    ON
  2. Re: Auxiliary Heater
    May 2013
    Wisbech
    8 Post(s)
    U would check fuse for for auxiliary heating, can you access 7D or 18 by VCDS?
  3. Re: Auxiliary Heater
    Mar 2009
    Cheshire
    Thanks for your reply. Where would the fuse be? Is it in the panel to the right of the dash once the door has been opened? When you say can you access 7D or 18 by VCDS can you just expand on what you mean? Thank you
  4. Re: Auxiliary Heater
    May 2013
    Wisbech
    8 Post(s)
    Error shows no signal to control module, if you choose component 7d or 18 ( which is aux heat) , is VCDS letting you connect to this component? If you are able to connect, you can check then measuring blocks for aux heating
  5. Re: Auxiliary Heater
    Mar 2009
    Cheshire
    I see. Controll module 18 is Aux Heat and no I cannot connect to it. I don't seem to have a 7D. The same fault also appears in the CAN gateway module 19. Is this fault code anything I need to worry about
  6. Re: Auxiliary Heater
    May 2013
    Wisbech
    8 Post(s)
    Yeah 18 is more common component in audi /vw cars. Aux heat it is electric heater inside our cabin connected to heating system. When temperature outside is low, and you will set high temperature on climatronic then aux heater starts working to warm up cabin faster while engine is still cold. It is up to you, how important this feature is.
    In your case I would look first for fuse otherwise it might be faulty module
  1. Auxiliary Heater remote
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-07-2011, 11:32 PM
  2. Please Help Auxiliary Heater Install
    Last Post: 19-07-2011, 11:27 PM
  3. Auxiliary Heater, is it possible?
    By hackeron in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2009, 10:56 AM
  4. auxiliary heater not working
    By itwasntmemate in forum Alhambra
    Last Post: 05-12-2008, 09:04 PM
  5. Auxiliary Heater not working
    By rikwalter in forum Alhambra
    Last Post: 30-12-2007, 11:45 PM
