Thread: Problems with air suspension on Audi Allroad 2007
  1. Problems with air suspension on Audi Allroad 2007
    Oct 2014
    Romania, Vrancea
    Hi all in this nice forum
    I was driving last week home from work and suddenly came the warning light for air suspension one the fault is like this
    1 Fault Found:
    02645 - Valves for Level Control System
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 200
    if i turn of the car it goes away, it comes back after 15 min or one hour, , the car lift quickly dosent loose air over night. compressor make 16 bar , it only put very little air in system around 2-4 bar and have a nice temp on 85-90 degree is brand new (2 months tops), I changed also the valve block rear springs are new as well...
    can it be the control module ? or does anyone have other ideas, I want to try to change control module wires are fine
    the car is an audi allroad a6 2007, ASB engine
    hope someone can help a bit
    Jacob
  2. Re: Problems with air suspension on Audi Allroad 2007
    Dec 2016
    London
    Did you get a response or managed to fix the problem with 2645 error code.
    I have the same problem with my Q7 error code (ODIS DISG System) 2645 003 Solenoids for Level Control System (intermitant).
    from Bosch ESI DISG system, I get error code of OA55 Level Control Valve Mechanical Fault (Error Sporadic).
    anyone out there please help, my car is on drive way since 2 weeks.
    Thanks in advance.
    Regards,
    Sanj
  1. Allroad Air Suspension Problems
    By Neil Young in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-12-2021, 06:34 PM
  2. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  3. Please Help Audi A6 Allroad 2007 3.0 TDI Rear Air Suspension
    By LordFrith in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-11-2014, 01:44 PM
  4. Question Audi Allroad 2.7 2007: Temporary Adaptive Air Suspension Failure?
    By Burlesy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-10-2014, 02:22 PM
  5. Audi allroad air suspension ride
    By mcilwaine in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-06-2013, 10:40 PM
