Thread: Seat ibiza 2003 aircon
  1. Seat ibiza 2003 aircon
    May 2016
    london
    Hi could anyone help,i have noticed when using my aircon niver of the runs cut in,i know that the fan works due to sitting in traffic and letting the engine heat up,i had checked the fuse's in the engine bay according to the haynes book.my aircon works and get nice and cold but i don't wont to keep running it if it's going to course me any problems
  2. Re: Seat ibiza 2003 aircon
    1837 Post(s)
    If the fan does not cut in at a standstill, eventually the pressure sensor will shut the AC off. Which engine type code is in your car?
  3. Re: Seat ibiza 2003 aircon
    May 2016
    london
    One fan cuts in at 89,ive never had the second fan cut in only the driver's side fan,where would i find the engine code,all i know is mines the 1.9 tdi PD
    Just found engine code it's ATD
  4. Re: Seat ibiza 2003 aircon
    1837 Post(s)
    It will be a 100PS ATD or 130PS ASZ and the system is the nearly the same for both albeit with a production break for slight differences on cars built after November 2002 so I will assume yours is the earlier version. The two fans are dual speed units and the interesting point is both are wired together on both speeds so if you have one fan working, the other is potentially faulty. The normal speed output is the one used by the AC and this is controlled along the thinner red/green wire. Both speeds are commanded by the radiator fan control unit plus the 130PS engine has an additional fan run on system. You need to establish if the control unit is being commanded to run by the AC control panel. If you can clarify your engine code and the production date, I can post a wiring diagram.
  1. A4 2003 aircon problems
    By besi_05 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2014, 12:08 PM
  2. Ibiza drivers seat
    By bigwayne in forum Ibiza - Cordoba
    Last Post: 09-11-2009, 11:52 AM
  3. Seat Ibiza...some questions
    By intertuning in forum Chat - Anything with wheels
    Last Post: 30-09-2008, 10:30 PM
  4. Seat Ibiza
    By P Groves in forum New Member Introductions
    Last Post: 28-05-2008, 03:01 AM
  5. new seat ibiza
    By ianbarrows in forum Ibiza - Cordoba
    Last Post: 27-08-2007, 09:37 PM
