Thread: Import Speed camera locations new Q7
Page 2 of 25 FirstFirst 123412 ... LastLast
Results 11 to 20 of 243
  1. Re: Import Speed camera locations new Q7
    Mar 2010
    10 Post(s)
    92 Post(s)
    If you can find a site online that has the info and in a format supported by the MMI then I'll try it right now... just not sure where to look (online)
    2016 Q7. Nuff Said.
  2. Re: Import Speed camera locations new Q7
    Oct 2015
    Derby
    I read a post a while ago on importing speed camera locations into the mmi of an A4. I've lost the bookmark but they were using the database from pocketgps world. I think there's a small fee though.
    Will definitely be doing this if it works!
  3. Re: Import Speed camera locations new Q7
    Nov 2008
    It should work as it's clear in the manual to be able to import POIs and it's clear on the option for POI notification so in theory this should just work.
    Hopefully the notification tone is not annoying. Mercedes do just one beep which is perfect.
    Sent from my SM-G935F using Tapatalk
    2012 Audi A7 SE, Midnight Blue, MMI Plus with touch, Adaptive Cruise Control, Lane Assist, Blind Spot Monitoring, Head Up Display, Audi Pre-Sense, 2wd 8 speed.
  4. Re: Import Speed camera locations new Q7
    Mar 2010
    10 Post(s)
    92 Post(s)
    If it's the same beep for if you choose to be alerted when near a petrol station then it's fine. It's a single beep
    2016 Q7. Nuff Said.
  5. Re: Import Speed camera locations new Q7
    Apr 2016
    Stansted
    135 Post(s)
    Sounds promising. Does it say what distance triggers the beep. I've been done twice ( at the same spot ) where a 60 goes to 30 and I didn't slow down quick enough. Not a built up area, so no schools or any real danger but they place one of those vans that can do you at 300m...
    MY16 Q7 S line 3.0 TDI (272) - Daytona Grey, Dynamic pack, Technology pack, Parking pack adv, Pan sunroof, Black leather, Bose, Matrix LED, Adv key, Driver/Pass elec memory, Sound insulating windscreen, Elec adj steering column, Heated rear seats, Heated windscreen, Rear side airbags, Audi smartphone interface, Ambient lighting, Heated steering wheel, Heated folding door mirrors.
  6. Re: Import Speed camera locations new Q7
    Nov 2008
    I knew the part about importing POI was somewhere. Weirdly the POI notification option is in the owners manual and the POI import is in the audi Connect manual. So as I thought I just need a POI database in the correct file format .csv for example and away we go. Then it will be interesting to see if it is then available to select in the notification section.
  7. Re: Import Speed camera locations new Q7
    #17
    Nov 2008
    So it's here under audi special destinations
  8. Re: Import Speed camera locations new Q7
    #18
    May 2016
    Devon
    Try Pocket GPS World - SatNavs | GPS | Speed Cameras who have a file that is updated weekly for s small subscription.
    I have used it on a Ranger Rover and a Volvo with no problem.
    They also have a free app called CamerAlert to try.
  9. Re: Import Speed camera locations new Q7
    #19
    Mar 2010
    10 Post(s)
    92 Post(s)
    So as a test I did a search for POI destinations and found a free database for LPG Petrol Stations in the UK. It was in CSV format, OV2, KML (Google Earth) etc formats. Note the file must be under 5MB in size
    I found the OV2 file (for Garmin Devices) worked. I logged into MyAudi and added a personal POI. Uploaded the OV2 file and a 'bmp' image of a LPG icon for the icon (if that makes sense)
    It uploaded as you can see below and I then hit "send to vehicle" and it said sent. I just need to go outside and see if it shows on the MMI in the Q7.
    If it works, then the principle works well. The Audi Connect guide is a little out of date as the page for uploading the POI has moved on the Audi Connect site, but its definitely there
    EDIT: I havent been to the car yet but the MyAudi site is confusing. It says transfer by SD card, yet has a "Send to Vehicle" option which I clicked on and it said sent. I clicked the Download Button next to it, thinking that is for the SD card but it just said "Sent to vehicle successfully" as well. lol
    2016 Q7. Nuff Said.
  10. Re: Import Speed camera locations new Q7
    #20
    Jul 2010
    uk
    92 Post(s)
    Quote Originally Posted by jimbg View Post
    This lists the Audi RNS-E system which I thought was the previous gen? Lots of threads on various Audi forums on how to add to those cars but can't find the A4 thread JMB mentions
  1. Discover Pro - Safety Camera Locations
    By steve scott in forum Golf MK7 - 2013 on
    Last Post: 14-02-2016, 09:23 AM
  2. Important Speed camera
    By M1tchy in forum Chat - Anything with wheels
    Last Post: 23-08-2015, 06:38 PM
  3. Speed Camera Alerts- What do you use?
    By chisteve in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-09-2011, 08:05 AM
  4. Speed Camera Karma
    By B6Andy101 in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 10-05-2009, 12:52 AM
  5. Red Light Speed Camera
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-04-2008, 12:13 AM
