Thread: Eclectic problem
  1. Eclectic problem
    May 2016
    Derry
    I have an 02 seat Alhambra my wipers hearted and headlights aren't working ? Any ideas
  2. Re: Eclectic problem
    1841 Post(s)
    What about the rear window wiper, heated rear window, rear fog light. I would expect this problem to be failure of the 75 terminal (black/yellow) from the ignition switch.
  3. Re: Eclectic problem
    May 2016
    Derry
    No bk wipers or heated Window or rear fog light
  4. Re: Eclectic problem
    1841 Post(s)
    You have no power on what is known as the "X Contact" which CAN be failure of the J59 X relay itself OR failure of the power feed to it OR failure of the command signal. The main clue here is the headlights, these are on the trigger line of the X circuit and not on the output of the X relay and this points directly to the 75 terminal output of the ignition switch. By bridging contacts 30, 15 and 75 on the switches plug, you can simulate a working switch.
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Replies: 19
    Last Post: 24-12-2011, 09:45 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
