Thread: Problems audi a3 2.0 no solution in sight
Results 1 to 1 of 1
  1. Question Problems audi a3 2.0 no solution in sight
    May 2016
    ourem
    have a good audi a3 2.0 140c 2006, the two days I've been in trouble, came to not catch. if I take the key and call me only light resistance (not erase) I know that the car will not get to give key takes 1/2 seconds, and goes down. I have to wait half an hour + -, then I will give key and turn on all the panel lights as usual already handle (strength light alloy and last 2 seconds goes as normal) someone has gone through this problem?
    already tested with:
    the 2 keys and do the same
    engine module (ECU) from another car
    quadrant (intromentos panel) and everything in it
    and even without radio
    here I leave the video breakdown
    with the original quadrant
    quadrant with another car and the deactivated imoblizador, also the tachometer does not work (so already caught but the fault remains
    it soon appears the lights all already know it works if only for the handle resistance and go down (illustrative video)
    sorry if the text has many errors but I'm from Portugal, I hope you understand
    thank you for your attention, and any tip is always welcome obliged
  1. How To Dim Headlights Solution For Audi A4 B6 (Reflector Replacment Guide)
    By headlightregen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2017, 10:27 AM
  2. Audi AMI retrofit, need some help to find a solution please
    By Audistorm in forum In Car Entertainment
    Last Post: 17-10-2015, 07:47 PM
  3. Question Sight steering wheel wobble at speed
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2012, 10:44 AM
  4. Attention is it a beautiful sight!
    By 95cabrio in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-03-2012, 11:15 AM
  5. 1997 2.8L exhaust problems/solution.
    By ScottA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-07-2008, 07:54 AM
