Thread: 2.8 30v v6 cold start issue plus other symptoms
  1. 2.8 30v v6 cold start issue plus other symptoms
    Apr 2016
    Uk
    Hi all
    Have an A8 2.8 2001, which has started having cold start issues.
    It can turn over endlessly when cold and not start, almost sounding and feeling like its flooded.
    Wait half an hour, and after hesitation will eventually fire.
    Once running for a few minutes will start first turn of key.
    Car runs seriously smoothly and plenty of power. No noises or misfires. Very responsive up to 3/4 throttle
    I was thinking temp sensor, however the temp guage seems to behave itself.
    Other possible related symptoms;
    Poor mpg (15mpg at best! That's being very gentle)
    Seems to pull better at half to 3/4 throttle than full throttle, like it's getting bogged down trying to burn the fuel at full throttle.
    My temp gauge never goes above 90, yet within 20 mins of gentle driving from cold, everything seems very hot - when I switch it off after just 20mins gentle use, I can hear all the metals in the exhaust and downpipes ticking away like crazy from the heat expansion/contraction as if I'd been bouncing it off the Rev limiter all day. It smells hot, and heat radiating from front arches and bonnet is colossal even after just 20mins.
    Water pump etc all done. This car has had no expense spared and runs like new apart from these symptoms and cold start issue.
    Could a dodgy temp sensor make it run rich, whilst not playing silly buggers on the gauge, or making it idle high??
    Confused as I would have thought temp sensor main culprit, but if it was essentially running on choke, wouldn't it idle high?
    Any help or advice greatly appreciated!
  2. Re: 2.8 30v v6 cold start issue plus other symptoms
    Oct 2015
    GB
    Could be the maf do a vcds
    Sent from my SM-A300FU using Tapatalk
  3. Re: 2.8 30v v6 cold start issue plus other symptoms
    Aberdeen
    63 Post(s)
    Check your coil packs and HT leads.
  4. Re: 2.8 30v v6 cold start issue plus other symptoms
    May 2013
    Wisbech
    8 Post(s)
    connect VCDS, it could be sensors, crankshaft position sensor, oxygen sensor, Maf, but without diagnostics u will not find out
  1. Cold start issue - independant garage reccomendations
    By bundao in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-01-2016, 11:30 PM
  2. Passat cold start issue how to fix
    By davepassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-07-2014, 07:30 PM
  3. Cold Start Issue
    By mike_low3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-11-2008, 02:58 PM
  4. cold start issue
    By tattooedferret in forum 80 - 90
    Last Post: 27-09-2008, 12:45 PM
  5. K-Jet Cold start issue
    By Dee-GTI in forum Golf MK2 - 1984 - 1992
    Last Post: 17-04-2008, 05:52 PM
