Thread: Notchy steering
  1. Notchy steering
    Apr 2007
    Hi all,
    I've done a quick search and couldn't find any posts with a solution to my issue, although it's been posted before.
    Ok so here goes; Audi A4 2012, multitronic, 143 (stop/start).
    Out of the blue whilst driving I noticed that when moving slightly left or right the steering seems to have a notchy effect almost as though it's on a cog/ratchet.
    It started yesterday morning happened on my route to work all the way there regardless of speed. On the route back and in the evening it didn't occur. So this morning, again, same thing all the way to work (16 miles). On route back on the motorway it was a lot more noticeable to the point where I could feel a resistance behind the wheel when negotiating bends.
    I decided to pull up after leaving the motorway and moved the wheel to full lock left and right and proceeded with my journey and low and behold steering was absolutely fine.
    Has anyone else seen this issue or know how to resolve it?
    Regards,
    Naz
  2. Notchy steering
    Coventry, United Kingdom, United Kingdom
    I have a similar issue on 2008 v6 multitronic....didn't do it when last with Audi tho!
    Be interesting to see if anyone has had a diagnosis and resolution
  3. Re: Notchy steering
    Jul 2007
    glasgow
    35 Post(s)
    sounds like an air lock
    which you would expect after an oil change of the power steering
    If you haven't changed the power steering oil, then check the reservoir to see if you have a leak
    However, going " Full Lock" on your steering is a bad idea. You should never hear the engine note or power steering note change , you will burst the seals
  4. Re: Notchy steering
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by niall campbell View Post
    I'm sure a modern system can cope with that. It tends to be a recommend procedure to bleed a PAS system. Maybe doing it for prolonged period of time may be harmful, but when would you do that?
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: Notchy steering
    Jul 2007
    glasgow
    35 Post(s)
    a modern system will cope with it as long as the seals last
    if your doing a lot of 3 point turns or bad driver, then see how long the seals last
  6. Re: Notchy steering
    Apr 2007
    Thanks for the info niall. I didn't actually lock it to the point of note change TBF I had read something similar to what you have just said. It hasn't happened for 2 days now and surprisingly today has been pretty cold too.
    I have to ask a novice question here but I can't locate the power steering reservoir to check it. Again it's the 2.0D 143 2012 stop/start engine. Can anyone point me in the right direction to that?
    Audi told me my car had the software update for this issue in 2013 and told me I had to book it in for them to investigate further..
  7. Re: Notchy steering
    Apr 2007
    Ok to add to this I've been told my car doesn't have a power steering reservoir due to it being electronically controlled.
  1. Notchy steering
    By gregpot2000 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-08-2014, 06:26 PM
  2. Notchy steering
    By BrianWM in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-10-2013, 10:03 AM
  3. steering issues... Newbie help please - chirpy - notchy
    By lawsy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2013, 10:23 PM
  4. Notchy Steering
    By John140 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-01-2012, 06:47 PM
  5. Notchy gearbox anyone??
    By CAL11 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-04-2009, 08:12 PM
