Thread: B8 R Line headlight and high beam bulb recommendations?
  1. B8 R Line headlight and high beam bulb recommendations?
    Feb 2016
    Milton Keynes England
    expecting my new non-LED R to turn up soon, I've already seen the excellent how-to to change the DRL's to LED which I'll be following and I'll also look to swap the headlight bulbs from the standard halogen. Does anybody have a recommendation for which good, clean, bright bulbs are recommended that don't bring up any faults, and is it just the main and high beam that needs replacing or are there any others I need to do at the same time to get the full set?
    Thanks!
  2. Re: B8 R Line headlight and high beam bulb recommendations?
    Aug 2011
    Tyne & Wear
    You'll need to change your fog lights if you want the full LED experience. Not sure what bulb type they are but if you follow the "excellent" ��LED guide you'll be able to check it out easily. I'd recommend getting Canbus equivalent bulbs from Autobulbs Direct. the Canbus resistors are built in and should stop any faults.
    do some before and afters!
    __________________________________________________ ___________
    Did have A4 Technik 170. Now got Passat B8 150 GT Indium Grey with LEDs.
  3. Re: B8 R Line headlight and high beam bulb recommendations?
    Mar 2016
    hull
    Hi, I've just fitted the Osram nighgtbreaker unlimited H7 to my GT, I've only fitted them to the dip beam. Very easy to do. They give a much whiter light, not driven much at night yet but the look is a lot brighter and cleaner
  4. Re: B8 R Line headlight and high beam bulb recommendations?
    Sep 2009
    scotland
    Getting a new 2016 Passat r via company, what headlights do they have as standard spec?
  5. Re: B8 R Line headlight and high beam bulb recommendations?
    Jul 2015
    Gloucester
    Quote Originally Posted by bigsteve102 View Post
    Hi mate, sorry to drag up an old post but do you have any info on how to change the dipped beam in the main cluster on the B8 Passat? I have done the DRLs to LED but would like to change all the halogens aswell.
    Is the Bulb accessible from the engine bay or do you need to go through wheel arch?
    Jamie
  6. Re: B8 R Line headlight and high beam bulb recommendations?
    Dec 2017
    Sweden
    Im replying (necro) to this because it comes up when searching for B8 passat headlight bulbs.
    To access the back of the light cluster theres is a panel in the wheel arch which once removed gives access.
    Be careful with this panel as I snapped both of mine doing the bulbs for the first time.
    H
  1. Replacing Headlight + Headlight Bulb on A3 Sline Black Edition 2011 Xenons
    By AudiRyda in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-06-2015, 07:32 PM
  2. Dipped Bulb Recommendations
    By Brydo666 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-06-2011, 10:45 PM
  3. Headlight dipped beam - bulb replacement
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-05-2011, 02:16 PM
