Thread: Audi A6 3.0 tdi quattro front subframe mounts
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Post Audi A6 3.0 tdi quattro front subframe mounts
    Dec 2013
    East Sussex, UK
    Haven't been on the forum for a while but was hoping someone may be able to assist with a few queries regarding front suspension components.
    I need to replace the front subframe mounts and also I'm looking at the front suspension arms at the same time.
    Audi are quoting approx. £36 each for the 4 subframe mounts - however, I can get FEBI BILSTEIN mounts for £12 each (fronts) and £15 each (rear) - does anyone have any experience of these - £142 for the Audi items (I'm assuming probably Lemforder who do a lot of the suspension components for VAG group) as opposed to £54 for the Febi Bilsteins.
    Audi part numbers 4F0399515C (front subframe bush x2) and 4F0399419E (rear subframe bush x 2)
    I'm also looking at the front suspension arm kits - you can pick them up for under £200 on ebay ; however, the genuine Audi 4F0498998 kit is nearly £1400 (yikes). Does anyone on here have any real world experience of using the cheaper kits.
    Any advice greatly appreciated. Thanks
    Audi A6 Avant - 3.0 tdi Quattro - S-line Le Mans edition
  2. Re: Audi A6 3.0 tdi quattro front subframe mounts
    May 2014
    Darlington
    78 Post(s)
    Why not just get the lemforder parts, as they are the same that Audi supply with the part number ground off. Use Lemforder webcat WebCat 3
    I would avoid like the plague the £200 ebay arms they won't last 5 minutes before you will have to replace them.
    I replaced all the arms & bushes front/rear on my A6 last year and used all lemforder parts, and replaced the shocks & springs with Eibach Pro B12 kit
  3. Re: Audi A6 3.0 tdi quattro front subframe mounts
    Nov 2012
    Somerset UK
    Why do you think you need to replace these parts, MOT advisories?
    Depends on your funds but a arm is only going to be as good as the quality of the bush that's in it....it's a shame that poly bush kits aren't widely available for our cars (although on an S-line it would probably be bone shaking)
    I has one of those £19 arms fitted 3yrs ago and it's still going strong with no play....so am guessing luck of the draw?
  4. Re: Audi A6 3.0 tdi quattro front subframe mounts
    Dec 2013
    East Sussex, UK
    Thanks for the replies - the car has 187k miles on the clock and I renewed the suspension last year with the Bilstein B12 kit as the original kit was way past its best. The subframe mounts are pretty split and generally knackered on the front subframe.
    Regarding the arms I think I'll take a view on them once I've sorted out the subframe mounts - there is some play/splitting of the upper arms bushes but they are not knocking or anything. I noticed it while I was renewing the brake discs due to some bad vibration when braking from 40 - 30 mph (which was caused by the disc as it moved when I swapped it to the other side).
  5. Re: Audi A6 3.0 tdi quattro front subframe mounts
    Dec 2013
    East Sussex, UK
    Renewed the Subframe bushes at the front. The 2 located under the engine were shot to pieces. Rear 2 on front Subframe were also pretty poor. Also renewed RHS engine mount as access was good and it was leaking. Didn't bother with arms in the end as checked them all thoroughly with wheels off and although some are showing signs of ageing there is no excessive play. Had full 4wheel alignment afterwards and have to say it feels so much 'tighter'. Went with Febi Subframe mounts in the end as the cost was £50 for all 4. The front Subframe mounts almost seemed to have suffered from water ingress. Also lots of dissimilar metal corrosion present between bushing housing and subframe mount.
    3 0 0
  6. Re: Audi A6 3.0 tdi quattro front subframe mounts
    Aug 2006
    Thessaloniki, Greece
    Quote Originally Posted by aw911 View Post
    Can you post the part numbers, thanks.
    Sent from my Nexus 6P using Tapatalk
    2006 Audi A6 Allroad 3.0 TDI Tiptronic
  7. Re: Audi A6 3.0 tdi quattro front subframe mounts
    Dec 2013
    East Sussex, UK
    Febi 38782 and 39691 - 2 of each.
    2 0 0
  8. Re: Audi A6 3.0 tdi quattro front subframe mounts
    Aug 2006
    Thanks, did you find the RHS engine mount from aftermarket or from Audi?
  9. Re: Audi A6 3.0 tdi quattro front subframe mounts
    Dec 2013
    East Sussex, UK
    Engine mount was 2nd hand off ebay. Cost about £20. A brand new one is over £150 from Audi. There is no oem equivalent for the 3.0tdi engine unfortunately. Febi do make them for other models though (eg 2.0tdi).
  10. Re: Audi A6 3.0 tdi quattro front subframe mounts
    Ireland
    hi.
    how much work was involved in changing subframe bushes? Is it straight forward or U need some special tools?
    I just replaced engine mounts and gearbox mount and still have a bit of slack in drivetrain.....
    2001 allroad 2.5 AKE manual -gone
    2007 A6 Estate 2.0 BRE manual
  1. Audi A4 Cab 2007 3.0 TDI Tip Quattro - Front Discs and Pads needed
    By JLBmatic in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-02-2014, 12:27 AM
  2. MK4 TDI Estate Front Suspension Uneven Top Mounts
    By rstmg in forum Golf MK4 - 1999 - 2004
    Last Post: 03-08-2012, 08:24 PM
  3. Front Subframe Problem?
    By baldbloke in forum Golf MK6 - 2009 - 2013
    Last Post: 09-04-2012, 01:36 PM
  4. Question 2003 1.9 TDi A4 Quattro B6 Front Subframe replacement
    By monkfish457 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-06-2011, 04:09 PM
  5. Question 2003 1.9 TDi A4 Quattro B6 Front Subframe replacement
    By monkfish457 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 16-06-2011, 10:42 AM
