Thread: Intermitant start fault
  1. Intermitant start fault
    Dec 2023
    Warrington
    Hi all so for the past month I've been trying to solve a fault with my 2013 2.0tdi bluemotion. If left for a couple of hours it won't start it doesn't try to crank or anything it just dings and lights up the following dash lights
    ABS, power steering, esc, tpms, engine light
    If you try to scan the car it says cannot scan basic obd as if it can't talk to thr ecu. Now take the key out and put it back in a couple times eventually the engine will crank and fire into life. At which point you can scan the car and it stores faults under Canbus, ABS, Power steering and central electronics modules the main fault that gets shared across the modules is
    01314 - cannot talk to ecm
    Now with the car now running you can clear all these fault codes and turn the car off and start it again and it starts and idles no issue what so ever. How ever leave it for a few hours and it'll do the same again no crank just errors until you take the key in and out a few times.
    When it's running if you drive it it sometimes cuts out momentarily and comes back to life. Other times it'll cut out and take a few tries with the key to get it going.
    Things I've tried to fix the issues -
    - New AGM battery on the car and coded to the car
    - replaced the 100 relay under the bonnet fuse box to a 644 relay
    - had an auto electrician come out and replace 2 other relays under the dashboard drivers side which apparently are connected with the ignition circuit.
    I'm at a loss of what to look for next. When it first happened I had a friend come with his 7k snap on scanner and that pointed a Terminal 30 - open / short to ground which pointed us to the terminal 30 relay under the bonnet thinking it was that but it wasn't.
    Can anyone shed some light on where to look from here at all please the cars been off the road a month already.
    Nick
  2. Re: Intermitant start fault
    1836 Post(s)
    Most people on here are going to need the results of a full car VCDS scan to help you. I have seen this on these cars and it was water damage to the engine ECU.
  3. Re: Intermitant start fault
    Dec 2023
    Warrington
    Cheers bud. I've heard you're in the UK actually where are you based?
    I can get a full scan from the Carista app which provides things like part numbers of each module and unit if that helps some along with any codes stored in each module. Or would more data be required?
    Like below (this was after I cleared the main fault codes)
    ECU info obtained with Carista 8.3 beta-7 for Android:
    VIN: WVWZZZ3CZDE134104
    CAN network gateway
    Part #: 7N0907530AH
    Component: J533 Gateway
    Software version: 1634
    ASAM/ODX identifier: [none]
    Coding: 462007 (hex)
    Fault codes:
    01300 Manufacturer-specific code
    03272 Manufacturer-specific code
    Engine
    Part #: 03L906018PR
    Component: R4 2.0l TDI
    Software version: 9979
    ASAM/ODX identifier: EV_ECM20TDI01103L906018PR
    Coding: 00190012042501080000 (hex)
    [No fault codes]
    ABS
    Part #: 3AA614109AQ
    Component: J104 C2 450M V
    Software version: [none]
    Coding: 4016 (decimal)
    [No fault codes]
    Parking brake
    Part #: 3AA907801H
    Component: J540 EPB4 VW-86
    Coding: 22167 (decimal)
    [No fault codes]
    Power steering
    Part #: 1K0909144P
    Component: EPS_ZFLS Kl. 195
    Coding: [none]
    [No fault codes]
    Steering angle
    [ECU not present]
    Steering wheel
    Part #: 3C9953501BN
    Component: LENKS.MODUL
    Software version: 0140
    ASAM/ODX identifier: EV_VW360SteerWheelUDS
    Coding: 1182250000 (hex)
    [No fault codes]
    Airbags
    Part #: 5N0959655AA
    Component: J234__108 VW10 H
    Coding: 12344 (decimal)
    [No fault codes]
    Instrument cluster
    Part #: 3AA920970J
    Component: KOMBI
    Software version: 0705
    ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
    Coding: 761D01 (hex)
    [No fault codes]
    Navigation
    [ECU not present]
    Radio
    [ECU not present]
    Media player
    [ECU not present]
    Immobilizer
    Part #: 3AA959433B
    Component: IMMO
    Coding: [none]
    [No fault codes]
    Tire pressure monitor
    [ECU not present]
    Heater & air conditioning
    Part #: 3AA907044AF
    Component: Climatronic
    Software version: 0303
    ASAM/ODX identifier: EV_Climatronic
    Coding: 0014004803 (hex)
    [No fault codes]
    Parking/steering assist
    Part #: 3AE919475C
    Component: PARKHILFE 8K
    Software version: 0018
    ASAM/ODX identifier: EV_EPHVA18VW47X0000
    Coding: 108002 (hex)
    [No fault codes]
    Central electronics
    Part #: 3AA937087F
    Component: BCM PQ47 M
    Software version: 0465
    Coding: 000800000000000000980080100000E447710088426D816064 80C7200041 (hex)
    Fault codes:
    00978 Manufacturer-specific code
    00979 Manufacturer-specific code
    Central electronics 2
    Part #: 7N0907532
    Component: EZE_2
    Coding: 00000008 (hex)
    [No fault codes]
    Body/convenience system
    Part #: 3AA959433B
    Component: KSG PQ47 ELV
    Coding: 18910A0052830E7634049C1D7C085FCE105C04 (hex)
    [No fault codes]
    Driver's door
    Part #: 3AA959701A
    Component: TUER-SG FT
    Software version: 0534
    ASAM/ODX identifier: EV_TSGFPQ35BRFVW46X
    Coding: 0202B7 (hex)
    [No fault codes]
    Front passenger's door
    Part #: 3AA959702A
    Component: TUER-SG BT
    ASAM/ODX identifier: EV_TSGBPQ35BRFVW46X
    Coding: 0202B6 (hex)
    [No fault codes]
    Rear left door
    [ECU not present]
    Rear right door
    [ECU not present]
    Battery regulator
    Part #: 7N0907534
    Component: Batt.regelung
    Coding: 030F1859 (hex)
    [No fault codes]
  4. Re: Intermitant start fault
    Dec 2023
    Warrington
    Here's the scan with faults
    ECU info obtained with Carista 8.3 beta-10 for Android:
    CAN network gateway
    Part #: 7N0907530AH
    Fault codes:
    01304 Manufacturer-specific code
    01305 Manufacturer-specific code
    01314 Manufacturer-specific code
    Engine
    Part #: 03L906018PR
    [No fault codes]
    ABS
    Part #: 3AA614109AQ
    Fault codes:
    01325 Manufacturer-specific code
    Parking brake
    Part #: 3AA907801H
    Fault codes:
    Power steering
    Part #: 1K0909144P
    Coding: [none]
    Fault codes:
    Steering angle
    [ECU not present]
    Steering wheel
    Part #: 3C9953501BN
    [No fault codes]
    Airbags
    Part #: 5N0959655AA
    [No fault codes]
    Instrument cluster
    Part #: 3AA920970J
    Component: KOMBI
    Fault codes:
    12648448 Manufacturer-specific code
    Navigation
    [ECU not present]
    Radio
    [ECU not present]
    Media player
    [ECU not present]
    Immobilizer
    Part #: 3AA959433B
    Component: IMMO
    Coding: [none]
    [No fault codes]
    [ECU not present]
    Part #: 3AA907044AF
    Fault codes:
    13701376 Manufacturer-specific code
    9485831 Manufacturer-specific code
    Part #: 3AE919475C
    [No fault codes]
    Central electronics
    Part #: 3AA937087F
    Fault codes:
    03678 Manufacturer-specific code
    Part #: 7N0907532
    Component: EZE_2
    [No fault codes]
    Part #: 3AA959433B
    [No fault codes]
    Driver's door
    Part #: 3AA959701A
    Fault codes:
    68108 Manufacturer-specific code
    Part #: 3AA959702A
    Fault codes:
    Rear left door
    [ECU not present]
    Rear right door
    [ECU not present]
    Battery regulator
    Part #: 7N0907534
    [No fault codes]
  5. Re: Intermitant start fault
    1836 Post(s)
    That scan is OK ish but full latest VCDS would be much better, the central electrics faults could be relevant and the missing devices telling.
  6. Re: Intermitant start fault
    Dec 2023
    Warrington
    2013 Passat B7 01314 code fault issues - YouTube
    Here's a video of what it's doing
  7. Re: Intermitant start fault
    Dec 2023
    Warrington
    So just managed to get it started and took it for a run I've managed about 9 miles then parked at a friend's let it sit for a bit and got back in started it again and it burst into life but when I set off down the road it cut out again and did it 3/4 times before it continued to run.
    On the way back about another 5 miles I put cruise control on and noticed my mileage didn't disappear in thr bottom left corner of the MFD Screen like it usually does when cruise control is on. I turned cruise off and on a couple times but it wouldn't display what cruise was set at although the cruise control was working as it should.
  8. Re: Intermitant start fault
    Dec 2023
    Warrington
    So quick update.
    Think it's been resolved. Original ECU was dead even though it would start on occasion and read fine sometimes. It had an intermittent fault somewhere so new ECU has got it back on the road.
  1. Fault Code 00519 Audi A6 C5 Power Loss intermitant
    By spottedhaggis in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-05-2011, 07:22 PM
  2. Question T4 intermitant non start from cold,
    By Transportergaz in forum The Commercial Range
    Last Post: 14-11-2010, 11:51 AM
  3. Please Help Intermitant start problem Audi Coupe 2.0E 8V 1995
    By Jonnovision in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 29-12-2009, 04:49 PM
  4. Intermitant Boost Fault (Code 17965)
    By dazrick68 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-11-2009, 08:51 PM
  5. Please Help Intermitant AC Fault
    By robinwells in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-05-2008, 09:27 PM
