Thread: No power to the ECU
Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 119
  1. Re: No power to the ECU
    #81
    Oct 2020
    Dundee , Scotland
    I have pmd you back not sure if it’s gone through as I’m fairly new to the group , it’s not shown in my sent messages but if you don’t get it I can try send my email somehow or if you want to send details over I will try help
  2. Re: No power to the ECU
    #82
    Jan 2021
    Skelmersdale
    After reading this thread I thought it's the right place for my issue.
    Passat B7 2.0 TDI CFGB Start/stop 2011
    It started last year in January.
    Coming to the car, trying to start but nothing, loads of faults lights up, parking sensors and radio not functional, fan in engine bay turns on. I tried connecting wires from another car and it has started but only for few seconds and it stopped again.
    Changed battery for new, no help.
    My friend suggested it could be water damaged ECU so we took it out and send to ECU testing. It came back without any faults so fitted back to the car and it worked flawlessly for a year.
    Few days back I went to work and after 6h it wouldn't start. Same problem. Unplugged battery for 5 mins, tried and started but only for few seconds again.
    Took ECU out and left it on radiator overnight, next day worked without problems but few days later same happened. Thinking it could be something with moisture I have sent it to ECU guys again but it has passed all their tests... So waiting for it to come back to me. Looking at the pattern I suspect it will start and work but not sure for how long lol
    When it wouldn't start, computer could not detect VIN on its own but read all the codes but did not manage to clear them.
    When it was fitted back after night it read VIN without problems.
    Does anyone have any suggestions where and what to look for?
  3. Re: No power to the ECU
    #83
    Oct 2020
    Dundee , Scotland
    Do you by any chance have a note of the codes that you got coming up on diagnostic? Is all the dash lights coming on and fan etc again too same as the first time this happened to you? My ecu had failed on me after checking almost everything I could as had similar issues but eventually swapped for another ecu and car ran great, decided to look in to my old ecu and find that the ecu itself was fine but had somehow corrupted files on it, restored all original files on it and the ecu is fine again. I read the other day a procedure that can be done on Passat to reset ecu and throttle body etc I’ll post the link maybe worth a try too. Here’s the link I had it saved it’s for a b5 but may still work
    VW Passat B5 Guides: Passat B5 Throttle Body & ECU Reset (Battery Replacement)
  4. Re: No power to the ECU
    #84
    Jan 2021
    Skelmersdale
    Got the ECU back from ECU Testing yesterday. They could not find any fault with it.
    I have fitted it back in today. So far so good but I think it's not over yet
  5. Re: No power to the ECU
    #85
    Sep 2008
    Saltburn, England
    Same Issue, No Comms with ECU, Fans on full
    Seems to have power to all the fuses & relays
    Will remove the Anti-Tamper bolts to check the ECU
    Is the ECU / Internal Moisture usually the fault?
    Monday,01,March,2021,15:12:35:26539
    VCDS Version: 20.12.0.0 (x64) HEX-NET CB: 0.4529.4
    Data version: 20201124 DS322.0
    Ross-Tech: Home
    VIN: WVWZZZ3CZBP348334 License Plate: *******
    Mileage: 233810km-145282mi Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61
    62 65 72
    VIN: WVWZZZ3CZBP348334 Mileage: 233810km-145282miles
    01-Engine -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    65-Tire Pressure -- Status: Malfunction 0010
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes Labels: 3AA-614-109.clb
    Part No SW: 3AA 614 109 M HW: 3AA 614 109 M
    Component: J104 C2 450M V4A1 0005
    Revision: --H07--- Serial number: 00000004061796
    Coding: 0002992
    Shop #: WSC 00028 028 00001
    VCID: B73E7F2AC62AAF3C72-80E2
    2 Faults Found:
    01314 - Engine Control Module
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 22
    Reset counter: 161
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.06.24
    Time: 14:00:33
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Bin. Bits: 00000000 00000000
    Voltage: 11.25 V
    Bin. Bits: 00011111
    Count: 217
    Hex Value: 0x0000
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.06.24
    Time: 14:44:42
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 7.25 V
    Bin. Bits: 00011111
    Count: 115
    Hex Value: 0x0000
  6. Re: No power to the ECU
    #86
    1837 Post(s)
    The battery is flat, in the ABS 2nd code it shows 7.25v.
  7. Re: No power to the ECU
    #87
    Sep 2008
    Saltburn, England
    Battery has been replaced, as it was the original battery & the running fans keep flattening it
    ECU removed & I have continuity on pin 69
    Rescanned with VCDS 21.3
    Tuesday,02,March,2021,11:48:43:26539
    VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4543.4
    Data version: 20210226 DS325.0
    www.Ross-Tech.com
    62 65 72
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    Address 01: Engine
    Cannot be reached
    Coding: 0002992
    VCID: B73E7F2AC62AAF33B2-80E2
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 95
    Reset counter: 161
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.24
    Time: 00:38:03
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 11.25 V
    Bin. Bits: 00011111
    Count: 217
    Hex Value: 0x0000
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
    Component: Climatronic H17 1010
    Revision: 00003001
    Coding: 0000000003
    Shop #: WSC 00028 028 00021
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_VW36.rod
    VCID: 804CD4F61B64288B43-80D4
    2 Faults Found:
    13701376 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [Motorsteuergerät - kein Signal/Kommunikation]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 9
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 00:38:03
    9481748 - High Pressure Sensor
    B10AE 14 [008] - Open or Short to Ground
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 00:43:49
    Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
    Part No SW: 3AA 937 087 A HW: 3AA 937 087 A
    Component: BCM PQ47 H 413 0452
    Revision: BB413001
    Coding: 000000000000000000180080140081E443516488406C816064 80C7200041
    VCID: B83C7C160B34A04BBB-80EC
    Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer 09031 26 0612
    Coding: 00B795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 120411 05 54 0403
    Coding: 0330ED
    2 Faults Found:
    00526 - Brake Light Switch (F)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.24
    Time: 19:34:42
    Freeze Frame:
    Term 15 Off
    Voltage: 10.70 V
    OFF
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.24
    Time: 19:33:32
    Freeze Frame:
    Term 15 On
    Voltage: 10.70 V
    ON
    ON
    ON
    OFF
    OFF
    Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
    Part No SW: 3AE 919 475 HW: 7N0 919 475
    Component: PARKHILFE 8K H04 0009
    Revision: -------- Serial number: 28291107749682
    Coding: 108001
    ASAM Dataset: EV_EPHVA18VW47X0000 001003
    ROD: EV_EPHVA18VW47X0000.rod
    VCID: FCB4A006778C4C6B1F-80A8
    No fault code found.
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
    Component: J234__102 VW10 HI 1918
    Revision: 22014000 Serial number: 003K0P6A0TT-
    Coding: 0012338
    VCID: CCD430C6AFAC3CEBEF-8098
    Subsystem 1 - Serial number: 6332MTS625650741
    Subsystem 2 - Serial number: 6342MTS636660751
    Subsystem 3 - Serial number: 6351HTS6N43CS9KR
    Subsystem 4 - Serial number: 6361HTS6CMRIS9KR
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
    Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
    Component: LENKS.MODUL 014 0140
    Revision: FF010040 Serial number: 20110408101598
    Coding: 1182250000
    ASAM Dataset: EV_VW360SteerWheelUDS A03004
    ROD: EV_VW360SteerWheelUDS.rod
    VCID: F2A88E3E25C80A1B45-80A6
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-TK6 H06 0022
    Coding: E20000
    Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
    Part No SW: 3AA 920 970 A HW: 3AA 920 970 A
    Component: KOMBI H20 0420
    Coding: 460F00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
    VCID: B12A4132E04E7103FC-80E4
    1 Fault Found:
    12648448 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [Steuergerät für Motor: keine Kommunikation]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 00:38:02
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 G HW: 1K0 907 951
    Component: J533 Gateway H41 1614
    Revision: H41 Serial number: 080411F1001509
    Coding: 461007
    VCID: B4244826175C442B97-80E0
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.24
    Time: 00:38:03
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3AA 959 433 HW: 3AA 959 433
    Component: IMMO 043 0399
    Revision: 00043000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: F6A0B22E81A0163B69-80A2
    Subsystem 1 - Part No: 3C0 905 861 J
    Component: ELV 029 0380
    3C0905861J ELV 029 0380
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7669743207
    Coding: 020000
    VCID: A81CAC56DB9430CB2B-80FC
    Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
    Part No SW: 3C0 035 279 HW: 3C0 035 279
    Component: RNS315 H05 0010
    Serial number: VWZAZ2L3320713
    Coding: 040004010400000000011000
    ASAM Dataset: EV_RNS315VWEUV1UDS A01005
    ROD: EV_RNS315VWEUV1UDS.rod
    VCID: E08CF476FB24888B23-80B4
    6 Faults Found:
    1048597 - Front Left Treble Speaker
    B1061 13 [009] - Open Circuit
    [tweeter front left open load]
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 19:41:22
    1048598 - Front Right Treble Speaker
    B1064 13 [009] - Open Circuit
    [tweeter front right open load]
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 19:41:22
    1048599 - Rear Left Treble Speaker
    B1066 13 [009] - Open Circuit
    [tweeter rear left open load]
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 19:41:22
    1048600 - Rear Right Treble Speaker
    B1068 13 [009] - Open Circuit
    [tweeter rear right open load]
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 19:41:22
    1048661 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    [CAN TO park distance control]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 00:43:48
    1048658 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    [CAN TO speed signal]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 00:43:48
    Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
    Component: TUER-SG FT 002 0530
    Revision: 12110009 Serial number: 0002608904
    Coding: 0202B7
    ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
    ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
    VCID: B522752214265D23A0-80E0
    Slave Driver:
    Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 004 0408
    Serial number: 00000002057477
    Coding: 000290
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 195 3201
    Revision: 00H20000
    VCID: B4244826D75C442B97-80E0
    2 Faults Found:
    03803 - Steering Angle Sensor for Steering Aid
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.24
    Time: 00:38:02
    Freeze Frame:
    Battery Volts: 11.5 V
    DU
    Temperature: 15.0°C
    Count: 2
    Steering Angle: 0.00°
    Count: 1
    SteerAng n.Init
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.24
    Time: 00:38:02
    Freeze Frame:
    Voltage: 11.50 V
    DU
    Temperature: 15.0°C
    RPM: 1498 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
    Component: KSG PQ47 ELV 043 0631
    Coding: 01910A0002860E76300494157C085FCE105C01
    Shop #: WSC 18798 014 67328
    Subsystem 1 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HORN H11 9005
    Subsystem 2 - Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
    Component: Innenraumueberw.004 0611
    2 Faults Found:
    00625 - Vehicle Speed Signal
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.24
    Time: 00:43:43
    01321 - Control Module for Airbags (J234)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.24
    Time: 00:43:45
    Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H41 1614
    Coding: 00000008
    VCID: EFAE874A3EFA27F3AA-80BA
    Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
    Component: Analoguhr 004 0003
    Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
    Component: TUER-SG BT 002 0530
    Revision: 14110009 Serial number: 0002615956
    Coding: 0202B6
    ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
    ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
    VCID: B620722E0920563BA9-80E2
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 004 0408
    Serial number: 00000002069667
    Coding: 000290
    Address 53: Parking Brake Labels: 3AA-907-801.clb
    Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
    Component: J540 EPB4 VW-55183 0007
    Revision: H18 Serial number: 00000000275996
    Coding: 0022067
    VCID: B3264B3AD25243138E-80E6
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 85
    Reset counter: 161
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.06.21
    Time: 11:24:41
    Freeze Frame:
    Voltage: 11.70 V
    Count: 71
    Speed: 0.0 km/h
    Hex Value: 0x1273
    Hex Value: 0x0001
    Hex Value: 0x1010
    Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H41 1614
    Coding: 030B185A
    VCID: F1AA813228CE3103BC-80A4
    Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
    Component: J367-BDM H07 0150
    Serial number: 00000000009370130638
    Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
    Part No SW: 3AA 907 273 B HW: 3AA 907 273 B
    Component: RDKBERU30 H08 0008
    Serial number: 10000000029158
    ASAM Dataset: EV_RDKBERU30 003010
    ROD: EV_RDKBERU30_003.rod
    VCID: B3264B3A1A5243138E-80E6
    1 Fault Found:
    12656671 - No Communication with Diagnostic Gateway
    U0146 00 [008] - -
    [Gateway keine CAN Kommunikation]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.02
    Time: 00:43:24
    End----(Elapsed Time: 01:49, VBatt start/end: 10.5V/10.4V. VIgn 10.5V)-----
    Address 19: DTCs cleared
    Address 09: DTCs cleared
    Address 03: DTCs cleared
  8. Re: No power to the ECU
    #88
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    On your latest scan it still shows low voltages " End----(Elapsed Time: 01:49, VBatt start/end: 10.5V/10.4V. VIgn 10.5V)----- "
    Can't you disconnect the fans until you get the engine running & avoid flattening the battery & give the battery a good charge.
    The fact that there is no communication with the engine module 01 could be that it is missing one or more +12v supplies, or just due to the low voltage it's getting from the battery.
    There are several +12v supplies it needs to function, but you will need a wiring diagram to check which pins on the ECU to check.
  9. Re: No power to the ECU
    #89
    Sep 2008
    Saltburn, England
    I'm aware of the voltage issues [The Passat is a long way from any power source to charge the battery whilst working on the car],
    This does not negate that the ECU is dead / not communicating.
    I have the ERWIN Diagrams & I've checked the power lines 3,5,6 & continuity with Pin 69.
  10. Re: No power to the ECU
    #90
    Sep 2008
    Saltburn, England
    Just to update the thread.
    The 2012 Passat's ECU was sent to ECUTesting & it was faulty, turnaround within a week [During Lockdown 3.0] & the car is running again after being sat for 3 months.
    Thanks for the advice & so glad it wasn't a broken wire.
    Battery fully Charged & new scan via VCDS 21.3
    Lots of fault codes, from the faulty ECU & all cleared & running fine.
    www.Ross-Tech.com
    62 65 72
    01-Engine -- Status: Malfunction 1010
    25-Immobilizer -- Status: Malfunction 0010
    65-Tire Pressure -- Status: OK 0000
    Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 BF HW: 03L 907 309 N
    Component: R4 2.0l TDI H24 9978
    Revision: 47H24--- Serial number: VWZCZ000000000
    Coding: 00190012042501080000
    Shop #: WSC 24977 002 1048576
    ASAM Dataset: EV_ECM20TDI01103L906018BF 003008
    ROD: EV_ECM20TDI01103L906018BF.rod
    VCID: EFAE874A36FA27F3AA-80BA
    8 Faults Found:
    5463 - Starter Control; Returned Message
    P3052 00 [036] - 50 Short to Plus
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Engine RPM: 1262.50 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 67 °C
    Intake air temperature: 64 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.700 V
    Unlearning counter according OBD: 40
    Engine control module reset status-Bits 0-7: 0
    Limitation: torque: 0.0 Nm
    Limitation: accelerator pedal: 41.1 Nm
    Cruise Control System (CCS): status-Bits 0-7: 201
    Accelerator pedal travel: 11.40 %
    Engine torque: -500.0 Nm
    Generator: load signal: 30.00 %
    4967 - Fuel Temp. Sensor A (G81)
    P0183 00 [036] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Engine RPM: 1207.50 /min
    Fuel consumption: 0.00 l/h
    Engine oil temperature: 79.3 °C
    Oil warning threshold: 14.660 mm
    Control Module temperature: 16.1 °C
    Oil fill level: 0.000 mm
    Outside temperature: -0.0 °C
    Fuel temperature: -40.0 °C
    5134 - Valve for Fuel Metering (N290)
    P0091 00 [036] - Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Engine RPM: 0.00 /min
    Coolant temperature: 63 °C
    Voltage terminal 30: 11.740 V
    Engine status: COENG_FINISH
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
    5281 - Mass Air Flow Sensor (G70)
    P0101 00 [036] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Throttle valve adapter: specified value: 100.00 %
    EGR Solen.val.: actual value: 100.56 %
    Charge air pressure: specified value: 1030 hPa
    Charge air pressure actuator: acknowledgment: 91.03 %
    Air mass: specified value: 354.4 mg/stroke
    Air mass: actual value (mg/stroke): 0.0 mg/stroke
    10092 - Neutral Gear Sensor
    P15A0 00 [036] - Electrical Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Neutral position sensor: current transmission angle: 20.00 °
    Neutral position sensor: adapted transmission angle: 0.00 °
    Transmission neutral position sensor voltage: 0 mV
    selected gear-Bits 0-7: 0
    5523 - Engine Start Blocked by Immobilizer
    P1570 00 [038] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Immobilizer snapshot A-Sia Error Snap A: 14 80 09
    Immobilizer snapshot B-Sia Error Snap B: 02 00 00
    9123 - Throttle Actuator Control System
    P2112 00 [036] - Stuck Closed
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Coolant temperature: 60 °C
    Intake air temperature: 63 °C
    Throttle valve adapter: specified value: 0.00 %
    Throttle valve adapter: actual value: 81.95 %
    Throttle valve adapter: offset closed: -1.14 %
    Throttle valve adapter: status-Bits 0-7: 0
    Throttle valve adapter: status-Bits 0-7: 55
    Throttle valve adapter: status-Bits 0-7: 43
    Throttle valve adapter: uncond voltage actual value: 3573.4 mV
    9124 - Throttle Actuator Control System
    P2111 00 [036] - Stuck Open
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Coolant temperature: 51 °C
    Throttle valve adapter: actual value: 88.31 %
    Throttle valve adapter: status-Bits 0-7: 40
    Throttle valve adapter: uncond voltage actual value: 3809.0 mV
    Readiness: 0 0 0 0 1
    Coding: 0002992
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 13
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.08.03
    Time: 00:03:29
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 9.75 V
    Bin. Bits: 00011111
    Count: 217
    Hex Value: 0x0000
    Revision: 00003001
    Coding: 0000000003
    ROD: EV_ClimaAutoBasis_VW46.rod
    1 Fault Found:
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 19:44:07
    Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
    Component: BCM PQ47 H 413 BCM PQ47 H 413 04520452
    Revision: BB413001
    Coding: 00B795
    Coding: 0330ED
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Coding: 108001
    1 Fault Found:
    13893632 - Function Restricted due to Insufficient Voltage
    U1400 00 [008] - -
    [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 00:04:34
    Coding: 0012338
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.08.03
    Time: 00:04:49
    Coding: 1182250000
    Coding: E20000
    Coding: 460F00
    2 Faults Found:
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 00:02:24
    13638912 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    [Steuergerät für Lenkhilfe: keine Kommunikation]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 00:09:23
    Coding: 461007
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.08.03
    Time: 00:00:21
    1 Fault Found:
    02861 - Electronic Steering Column Lock Check Sum Error
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00111110
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 0 km
    Time Indication: 0
    Coding: 020000
    5 Faults Found:
    1048580 - Function Restricted due to Insufficient Voltage
    U1400 00 [008] - -
    [restriction due to undervoltage]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 00:04:34
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 19:44:10
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 19:44:10
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 19:44:10
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 233819 km
    Date: 2021.03.12
    Time: 19:44:10
    Coding: 0202B7
    Slave Driver:
    Coding: 000290
    Revision: 00H20000
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.08.03
    Time: 19:44:06
    Freeze Frame:
    Voltage: 10.38 V
    DU
    Temperature: 14.0°C
    RPM: 1498 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    00750 - Warning Lamp
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Voltage: 10.25 V
    PD
    Temperature: 12.0°C
    RPM: 1498 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    02391 - Terminal 30 Reference
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.50 V
    PD
    Temperature: 6.0°C
    Speed: 50.0 km/h
    Torque: 0.0 Nm
    Torque: 0.000 Nm
    Term 15 On
    1 Fault Found:
    01134 - Alarm Horn (H12)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 4
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.08.03
    Time: 00:00:13
    Coding: 00000008
    Coding: 0202B6
    Slave Passenger:
    Coding: 000290
    Coding: 0022067
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 107
    Reset counter: 201
    Mileage: 233819 km
    Time Indication: 0
    Date: 2015.07.01
    Time: 11:24:41
    Freeze Frame:
    Voltage: 11.70 V
    Count: 71
    Speed: 0.0 km/h
    Hex Value: 0x1273
    Hex Value: 0x0001
    Hex Value: 0x1010
    03182 - Clutch Position Sensor (G476)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 201
    Time Indication: 0
    Freeze Frame:
    Voltage: 11.10 V
    Count: 55
    Speed: 0.0 km/h
    Hex Value: 0x1273
    Hex Value: 0x0001
    Hex Value: 0x1010
    Coding: 030B185A
    End----------(Elapsed Time: 03:20, VBatt start/end: 14.7V/14.8V)-----------
    Gateway Installation List: 7N0 907 530 G
    01-Engine -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    62 65 72
    Coding: 0002992
    Revision: 00003001
    Coding: 0000000003
    Revision: BB413001
    Coding: 00B795
    Coding: 0330ED
    Coding: 108001
    Coding: 0012338
    Coding: 1182250000
    Coding: E20000
    Coding: 460F00
    Coding: 461007
    Coding: 020000
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Component: TUER-SG FT 002 TUER-SG FT 002 05300530
    Coding: 0202B7
    Slave Driver:
    Subsystem 1 - Part No: 3C0 959 704 Labels: 1K0-959-70X-GEN4.CLB
    Coding: 000290
    Revision: 00H20000
    Coding: 00000008
    Coding: 0202B6
    Slave Passenger:
    Coding: 000290
    Coding: 0022067
    Coding: 030B185A
    End----------(Elapsed Time: 03:10, VBatt start/end: 14.7V/14.7V)-----------
  1. Ecu power suply relay
    By juleshs1968 in forum Beetle 2000-
    Last Post: 29-04-2015, 11:36 PM
  2. ecu power upgrade/ swap for passat possible???
    By 930JON in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2010, 02:12 AM
  3. Question PLEASE HELP..is juddering and loss of power due to a recall on the ECU..?
    By aogriffith in forum Golf MK5 - 2004 - 2009
    Last Post: 10-03-2010, 11:03 AM
  4. Polo 1.9TDI S ECU Power steering?
    By colinayr in forum Polo - Derby - Lupo - Fox
    Last Post: 30-10-2008, 10:25 AM
  5. Question Location of ECU power relay
    By Unforgiven2 in forum Bora - 1998 - 2005
    Last Post: 08-10-2008, 09:48 PM
