Thread: No power to the ECU
Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 119
  1. Re: No power to the ECU
    #61
    Feb 2018
    Karlstad, Sweden
    Hi Crasher!
    Yesterday we checked car. Starting working fine. We read and cleared error codes.
    This morning I started the diesel heater by remote and when I tried to start it wouldn`t start.
    Engine, ABS, and ESP lamp is yellow.
    We can`t read error codes now, no communication. Using Auto-com as communication program.
  2. Re: No power to the ECU
    #62
    Feb 2018
    Karlstad, Sweden
    We tested the auto-com on other car no problem so the comunication is only on my car.
    Any ide?
    Checked fuse F7, F15 both ok
    Also checked F4, F13 also ok
    Now all fuses checked in engine bay and left side "door" panel.
  3. Re: No power to the ECU
    #63
    Feb 2018
    Karlstad, Sweden
    Total failure of ECU would that cause no comminication?
  4. Re: No power to the ECU
    #64
    Feb 2018
    Karlstad, Sweden
    Picture of the dashboard when the car won`t start
  5. Re: No power to the ECU
    #65
    Feb 2018
    Karlstad, Sweden
    ECU before and after restoration. The car now working fine again.
  6. Re: No power to the ECU
    #66
    1841 Post(s)
    What happened to that? It looks like it has been in a fire?
  7. Re: No power to the ECU
    #67
    Mar 2019
    Isle of Skye
    Apologies to jump on such an old thread but seems prudent to keep all this info together in case anyone is unfortunate enough to end up here!
    I've followed this thread and thanks to all input I've managed to get my friends golf (2.0 tdi 140 mk6 59plate) running. All be it with the main 100 relay on the sb board hot wired. It seems at its not switching the earth or supplying 12v to the low power side. I've checked everything I can and cannot seem to find anything wrong besides that.
    Symptoms were cutting out. Then restarted for less than 2 minutes and then dead. Cranking but no prime etc and no communication with the ecu via vag com. Manually closing the relay on SB would allow engine start and vagcom connection.
    Any ideas on what next? I can jumper the wires obviously but I'm struggling to find a switched live which doesn't disappear on cranking?
    Thanks for any input!
  8. Re: No power to the ECU
    #68
    1841 Post(s)
    Can you private message me the cars reg number?
  9. Re: No power to the ECU
    #69
    Mar 2019
    Isle of Skye
    I haven't got enough post count. How about this
    LO59
  10. Re: No power to the ECU
    #70
    Mar 2019
    Isle of Skye
    Obk
  1. Ecu power suply relay
    By juleshs1968 in forum Beetle 2000-
    Last Post: 29-04-2015, 11:36 PM
  2. ecu power upgrade/ swap for passat possible???
    By 930JON in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2010, 02:12 AM
  3. Question PLEASE HELP..is juddering and loss of power due to a recall on the ECU..?
    By aogriffith in forum Golf MK5 - 2004 - 2009
    Last Post: 10-03-2010, 11:03 AM
  4. Polo 1.9TDI S ECU Power steering?
    By colinayr in forum Polo - Derby - Lupo - Fox
    Last Post: 30-10-2008, 10:25 AM
  5. Question Location of ECU power relay
    By Unforgiven2 in forum Bora - 1998 - 2005
    Last Post: 08-10-2008, 09:48 PM
