Thread: No power to the ECU
Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 119
  1. Re: No power to the ECU
    #41
    1841 Post(s)
    One point I can make without identifying which diagram is correct is that the J317 relay is the “Terminal 30 voltage supply relay, on the onboard power supply control unit” and is powered by fuse 15 in the dash side fuse board, the OPS unit is under the dash and the relay is mounted on the front panel at position B4 marked KL30 and it powers the interior, rear centre reading, front reading, luggage and glove compartment lights.
    The engine ECU is powered via fuse 13 from relay J322 at position R1, both in the under bonnet fuse box and it splits into three feeds going to the ECU large plug at pins 3, 5 and the relay J322 is commanded by the ECU from pin 49 of the same plug. This feed line is called line 87 and it also feeds items such as the N75 valve and the lambda sensor heaters. The ECU is triggered by the line 50 relay which is called J682 and it is at position D2 under the dash below the onboard supply unit and it’s feed to the ECU goes through fuse 1 in the dash side fuse board and to the ECU, it is commanded by the onboard supply unit on instruction from the steering column ECU so I think it is J682 you are looking at.
  2. Re: No power to the ECU
    #42
    1841 Post(s)
    It was made on 5/11/2007 so it SHOULD be the latter wiring diagram but it is only 5 days into the change point.
  3. Re: No power to the ECU
    #43
    Feb 2018
    Karlstad, Sweden
    Hi!
    I got a similar problem.
    My Passat, 2012 2,0 tdi CFFB manual with start/stop, engine shuts down for time to time, ABS, ESP and engine warninglights is on.
    When reading the error codes it is only one 01314 no communication with ECU. Could be that ECU is missing power perhaps.......
    Any tip on trouble shooting this?
    Greatful for all help I can get for this issue
    Anyone having electronic scheme for this one?
    Thanks in advance!
  4. Re: No power to the ECU
    #44
    1841 Post(s)
    Which controller are you seeing this fault code in, the CAN BUS?
  5. Re: No power to the ECU
    #45
    Feb 2018
    Karlstad, Sweden
    The controller for the ABS (anti break system)
  6. Re: No power to the ECU
    #46
    Feb 2018
    Karlstad, Sweden
    Posting a couple of pictures
    Some more info
    VOLKSWAGEN, VW 3C
    WVWZZZ3CZCE167651
    e1*2001/116*0307*31
  7. Re: No power to the ECU
    #47
    1841 Post(s)
    Contrary to what almost everyone thinks ABS stands for it is a rare example of a German language car technology acronym being widely adopted, mainly because it can be misinterpreted and mean the same thing, it actually stands for AntiBlockierSystem.
  8. Re: No power to the ECU
    #48
    1841 Post(s)
    Sorry, got interrupted for some household DIY interaction. The CAN BUS unit is susceptible to water damage but it is probaly the ABS ECU, can you fault code scan it?
  9. Re: No power to the ECU
    #49
    Feb 2018
    Karlstad, Sweden
    That makes sense, anti blockier system, describes more what the real functionally is.
  10. Re: No power to the ECU
    #50
    Feb 2018
    Karlstad, Sweden
    Yes with help from a friend.
    The error code is 01314 No communication with ECU.
    Problem is also that this issue is intermintent.
    Right now the car is working fine.
    It has happened 2 times.
    First time I could start again after a few seconds and drove for 2-3 days.
    Second time it stopped I could restart but dead again after couple of 100 meters. Started few times more but not for more that 50-100 meters.
    Had to tow it back home. When finilay home it startaed again.
    Don`t dare to use the car as it is now.
    My amateur guess is that the ECU has no power when this happens. What do you think Crasher
  1. Ecu power suply relay
    By juleshs1968 in forum Beetle 2000-
    Last Post: 29-04-2015, 11:36 PM
  2. ecu power upgrade/ swap for passat possible???
    By 930JON in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2010, 02:12 AM
  3. Question PLEASE HELP..is juddering and loss of power due to a recall on the ECU..?
    By aogriffith in forum Golf MK5 - 2004 - 2009
    Last Post: 10-03-2010, 11:03 AM
  4. Polo 1.9TDI S ECU Power steering?
    By colinayr in forum Polo - Derby - Lupo - Fox
    Last Post: 30-10-2008, 10:25 AM
  5. Question Location of ECU power relay
    By Unforgiven2 in forum Bora - 1998 - 2005
    Last Post: 08-10-2008, 09:48 PM
